Adjustable low pass filter
saurabhkarnik
Joined Jun 22, 2008
22
hey guys... could u please tell me if it is possible to design an adjustable LPF between 100hz-1Mhz by using varicap or something.... what i'm talking is it possible or completely hypothetical... if not possible in what frequency ranges should i use different adjustable filters
Audioguru
Joined Dec 20, 2007
11,248
A varicap is used at 100MHz, certainly not at 100Hz.
You might be able to find a varicap used for an old AM radio that tunes down to 540kHz.
20 or 30 years ago a "transconductance amplifier IC" was used as the variable resistor in a lowpass filter. CA3080, LM13600 and LM13700 rings my bell.
Wendy
Joined Mar 24, 2008
23,810
100Hz to 1 Mhz, the range is a bit wide. It might be possible to make an active filter, but not very likely. 100Hz to 10Khz is a lot closer I would think.
In the case of an active filter the variable component would be a resistor or two (you can gang resistors on one shaft).
saurabhkarnik
Joined Jun 22, 2008
22
how about this
if i make a rc filter cutoff will be given by 1/rc..
so if i use a pot or a varicap and use stepper motor to vary it by microcontroller is it possible...
