Going to keep this simple I want to know if there is a way to get a 0-90 ohm rheostat to a range of 3-64 ohms? I can provide more information for application purposes if necessary.
It doesn't. It takes the potentiometer down to 61 ohms so that plus the 3 ohm resistor makes 64 ohms. If you want 64 ohms, use 222 ohms in parallel.I can't understand how the 189 ohm resistor takes the rheostat down to 64 ohm
But here, you get the answer in 4 minutes.I tried asking our master electrician at work if it would be possible he just told me it would be to much work
Exactly why is it easier to get random strangers to help with personal projects but, people you work with on a daily basis can't give you the time of day?But here, you get the answer in 4 minutes.
It is likely he doesn't know how to do this. Electrical and electronics are very different fields. Electricians install wires. Electronics people design circuits.people you work with on a daily basis can't give you the time of day?
No randomness... If you call for a 12 at allaboutcircuits.com, you getExactly why is it easier to get random strangers to help with personal projects...
No problem. My best friends call me, "weird".no comment about the "strangeness" of #12!
My relatives gave me the title Cliff Claven!It wasn't until many years later that I realized most people couldn't care less about how things work.
I was a nerd.
A mother brings here awkward child to the doctor and says, "He reads text books instead of plays with his friends, actually he doesn't make friends, he would rather take the radio apart than listen to it - in fact, he has taken apart and re-assembled nearly every expensive device in our house. What is wrong with him, doctor?" Doc says, "let me run a few tests". He come back a few minutes later and says, "I'm sorry ma'am, there is nothing we can do about it. Your son will be an engineer."When I was a kid I had to know how everything worked, both mechanical and electrical.
(It bugged me no end that I couldn't figure out how an automobile rear-end differential worked, since I couldn't see how that could be done with gears. It was a eureka moment when I saw one taken apart in a repair shop and realized the trick was that two of the gears rotated with the drive gear.)
I was a nerd.
