Hi, I'm trying to add protection to some SSR's, I think I have everything sorted out but would like some input if possible.
This is a power bar that will have 8 relays total, I only drew up 2 as they are all the same.
The SSR is a Hoymk SSR-D3808HK, it has 1.5kV isolation, internal snubber and rated at 8amps up to 380VAC.
The input of power bar will be 120-240 VAC and load could also be between 120-240 VAC.
For the TVS's I selected 1.5SMC300A (click for datasheet)
The fuses will be slow blow 5SF 5-R
Should MOV's be added?
