HI....my project title is microcontroller based vibration amplifier and in that for interfacing lcd my sir has used icl7106 which is having a2d converters(from datasheet) n its output goes to lcd..the output is digital that is sure n now i want to get all that output controlled n analysed in or via pc...hw can v do it?can't v interface it to rs232?is there any other ic who can make this output compatible with rs232?hi m new member of this site n i want urgent help in my clg project.i have interface icl 7106 which is atod converter with rs232.i need schematic n code for this in c.....
can v take the output of icl7160 into microcontroller n then can v interface with rs232?hi m new member of this site n i want urgent help in my clg project.i have interface icl 7106 which is atod converter with rs232.i need schematic n code for this in c.....
thanx 4 reply, i would like to know that will this ic able to interface with lcd and rs232 both?plz tel meThe ICL7106 is a 3 1/2 digit device, which means a resolution of 11 bits. For something with a bit better resolution and the interface for a microprocessor, you could use this one - http://www.intersil.com/cda/deviceinfo/0,0,HI-574A,0.html.
by Robert Keim
