Adapting Linkwitz-Riley active circiut for single supply operation
0ri0n
Joined Jan 7, 2025
190
Inverting input -> output-> V- and V+ (internal to opamp) -> ground.
If that is wrong, I don’t see how a voltage follower ever works, since the only connection of the inverting input is to the output.
The non-inverting inputs have no DC-path. A voltage follower doesn't work under this circumstance either.
BobTPH
Joined Jun 5, 2013
11,647
I did not say anything about internal bias resistors. The output has one transistor to V+ and one to V-, which can never both be high impedance. I still don’t see why this is not a DC path to ground.
Irving
Joined Jan 30, 2016
5,195
The op amps have no Vcc/2 bias voltage, the non inverting inputs are floating as there is no DC path anywhere. Only performing an AC sweep analysis is misleading as it doesn't show that the circuit doesn't really work as expected ;-).
I'm surprised you posted that circuit, which has no DC paths for both U1's and U2's (+) inputs. :eek:
You don't have a DC path to ground on the non-inverting inputs.
Yeah, my bad. That's what happens when you're rushing because DW is waiting to go out to garden centre...
I did do a transient check and it showed it was working ok. It wasn't until much later, after reading the comments, that I looked closer; it seems the LM324 library I was using (from Siemens I think) was a behavioural one that didn't care about little things like biassing. Swapping with a 'proper' TI library and it all goes badly wrong :rolleyes::eek:... Lesson learnt!
And the trip to the garden centre cost me £600 for another, admittedly very nice, Japanese Maple (Acer P. "Garnet") to add to our growing collection of them :oops::rolleyes:
