Hi guy's I could use a little assistance to work out some 12 v dc wiring .I wish to have a timer to extend an actuator and then a switch to manually retract the actuator.The usage is for a roosters night box.At night I need to be able to flick a switch to extend the actuator to open the door ,then place the bird inside and then flick the switch to close it .In the morning I need the timer to give power to the actuator to extend and open the door automatically so the bird can get out and then at a later time I need to be able to flick a switch and manually retract the actuator and close the door .Many thanks in advance.. List of some of the bits and bobs I have ... ..http://www.ebay.com.au/itm/161552313910?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT ...... http://www.ebay.com.au/itm/112009092626?_trksid=p2057872.m2749.l2649&var=410949586181&ssPageName=STRK:MEBIDX:IT .... http://www.ebay.com.au/itm/221759451485?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT ....... http://www.ebay.com.au/itm/Car-20A-...877603?hash=item33caed3de3:g:~gAAAOSwV0RXso5z Edit the actuator has built in limit switch's but I would have to use external ones as I cannot position the actuator properly
