Access ETM of Nucleo F401RE without using a debug kit
35,170
I have looked into IAR Terminal I/O utility.
In your code, you can have:
printf("Hello World\n");
This will display the message in the Terminal I/O Output window. Of course, you have to have IAR running in Debug mode.
Using the CP2102 would be a stand-alone method of monitoring program progress.
Lorenzo Ruscitti 1
Joined Nov 30, 2018
24
I wasn't talking about the display in the last message. I was saying if changing the value of the pointer, as I did in my code, it really changes my code, this I was wondering. Thanks
35,170
Sorry, I was not discussing whether your code changes. I am discussing the whole purpose of this thread with regards to debugging and monitoring the progress of your code. You wanted a way to monitor the behaviour of the code without using IAR debug. I have given you one method of doing so.
As for changes to your code, changing the contents of a string does not change the code.
Why are you concerned about this?
Hi and thank you for your availability
Because to activate the ETM I need to write the value 0xc5acce55 in a register of ETM.
We are going around in circles.
I am suggesting that you stop using the ETM.
Why are we turning in circles? What is not clear to you?
I can not choose not to use it is a task that I was assigned?
If I asked you: Write me a code that accesses the register of ETM called Etmlar, with address 0xe0041fb0, and in this address write the value 0xc5acce55. How would you do that?
Thank you
35,170
Thank you
I would not do it because I see no reason to do it.
I would write:
ETM->LAR = 0xC5ACCE55;
What is the difference between what you wrote to me and what I wrote?
Me:
#define UNLOCK 0xC5ACCE55 // Value to write in ETMLAR useful to unlock the ETM
#define ETM_LAR 0xE0041FB0 // Address of ETM_LAR
unsigned int *p_2 = (unsigned int*) ETM_LAR;
*p_2 = UNLOCK;
You:
35,170
Me:
*p_2 = UNLOCK;
You:
My method is called "direct addressing".
Your method is called "indirect addressing".
