Access ETM of Nucleo F401RE without using a debug kit
Lorenzo Ruscitti 1
Joined Nov 30, 2018
24
Post your code in the AAC forum text.
I will show you how to surround the code with cod tags.
This is my main.c
Code:
#include "main.h"
#include "stm32f4xx_hal.h"
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USART1_UART_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval None
#define ETM_CR  0xE0041000 // Address of ETM_CR
#define ETM_LAR 0xE0041FB0 // Address of ETM_LAR
#define UNLOCK  0xC5ACCE55 // Value to unlock ETM
#define ETM_LSR 0xE0041FB4 // Address of ETM_LSR
// select your desired serial device
void putc(char ch)
  while (!(UART1->ISR & UART_FLAG_TXE) );
  UART1->TDR = ch;
void puts(char *s)
  while (*s) putc(*s++);
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_USART1_UART_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
unsigned int *pointer_1 = (unsigned int *)ETM_CR;
unsigned int *pointer_2 = (unsigned int *)ETM_LAR;
unsigned int *pointer_3 = (unsigned int *)ETM_LSR; // The content of this register, when ETM is locked, is 1.
                                                   // when is unlock, is 0.
unsigned int var_1;
unsigned int var_2;
unsigned int var_3;
unsigned int var_4;
var_1 = *pointer_1;
var_2 = *pointer_2;
//To unlock ETM, the content of ETM has to be UNLOCK
*pointer_2 = UNLOCK;
var_2 = *pointer_2;
var_3 = *pointer_3;
sprintf(?);
printf("Value: %p\n", var_3);
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
    /**Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE2);
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    /**Configure the Systick interrupt time
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
/* USART1 init function */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart1) != HAL_OK)
/** Pinout Configuration
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOA_CLK_ENABLE();
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @param  file: The file name as string.
  * @param  line: The line in file as a number.
  * @retval None
void _Error_Handler(char *file, int line)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  while(1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
35,170
Create a char array such as
char mystring[80];
Use the sprintf( ) function in the same way that you would use printf( ) except you include the mystring in the parameter list:
sprintf(mystring, "Hello World\n");
Now pass the string to prints( )
prints(mystring);
Lorenzo Ruscitti 1
Joined Nov 30, 2018
24
char mystring[80];
prints(mystring);
OK But what should I save in 'mystring' of my code?
Lorenzo Ruscitti 1
Joined Nov 30, 2018
24
The sprintf( ) function will save whatever you want into the designated string.
In the example shown, "Hello World\n" will be stored in mystring[ ].
Ok i understand, in my case my "Hello wolrd" is a content of the pointer. For example var_1 = *pointer_1.
So i have to do this: sprintf(mystring, var_1); Without the "" because I have to print the contents of the variable, right ?
35,170
printf( ) and sprintf( ) are both "formatted" output functions.
Hence you can write:
sprintf( mystring, "The temperature is %d C\n", temp);
Lorenzo Ruscitti 1
Joined Nov 30, 2018
24
Ok perfect. Thanks
The Nucleo - PC connection is as follows, shown in image 8.
The settings of IAR are in images 1 and 2.
Tell me what do you think.
35,170
You still have one little detail to work out which I intentionally did not discuss.
What are you going to do with the serial data transmitted by UART1?
Lorenzo Ruscitti 1
Joined Nov 30, 2018
24
With this piece of code, through the use of pointers, I want to go see the contents of some of the registers of ETM. To do this I use pointers to particular memory addresses and then I need to print myself on video, through the function that you told me, their content.
After seeing their content I have to change the contents of some logs. This I did always through the use of pointers like this: * pointer_2 = 0xc5acce55;
My concern and if doing so I REALLY change the contents of that memory address.
Code:
unsigned int var_1;
unsigned int var_2;
unsigned int var_3;
unsigned int var_4;
var_1 = *pointer_1;
var_2 = *pointer_2;
var_2 = *pointer_2;
var_3 = *pointer_3;
35,170
My question is: Where are you going to see this information? What display are you going to use to see this string?
35,170
Assuming that there will be times when you want to test your system without using IAR, you would go and get a CP2102 USB-to-UART bridge.
With this, you send the TXD to RXD on the CP2102 which is plugged into a USB port on your PC.
Then you use a PC terminal program such as HyperTerminal or puTTY to display the information.
Lorenzo Ruscitti 1
Joined Nov 30, 2018
24
Ok
Ok
But about my code do you think that by doing it that way I can actually change the contents of the registers ?
Since I have the impression that I can read the contents of the logs but in writing it seems to me that I do not write directly on the registers but only on the pointer variable.
