Why?As I am intending to measure current at the high-side)
Measuring on the low side eliminates the need for a differential amp and simplifies the circuit.
Low-Side Method Cannot Detect Fault DetectionWhy?
What kinds of faults do you want to detect?Low-Side Method Cannot Detect Fault Detection
Load leakage currentWhat kinds of faults do you want to detect?
Leakage to where?Load leakage current
too earth and also short circuitLeakage to where?
Then just use the AC high-side as the common circuit reference instead of neutral.too earth and also short circuit
How do you propose to measure earth leakage unless you measure both the live current and the neutral current?too earth and also short circuit
