Its only simple if you know the answer... Nevermind, thank you
B Thread Starter Biggsy100 Joined Apr 7, 2014 88 Jul 29, 2014 #21 Its only simple if you know the answer... Nevermind, thank you
B Thread Starter Biggsy100 Joined Apr 7, 2014 88 Aug 6, 2014 #22 These are my latest workings, not sure at the beginning of each segment if I should be adding 314.2 as a cycle or not? Attachments Workings.pdf 155.2 KB Views: 14
ericgibbs Joined Jan 29, 2010 21,637 Aug 7, 2014 #23 Hi, Ref your PM, Attached is a marked up version of your pdf work sheet. Make sure that your calculator is set for Radians NOT Degrees. Work thru the sheet and compare your answers. Calculate each part of the equation. E EDIT: Added an LTS image showing the 3 part frequencies and a composite plot. It should help you visualise the problem. Attachments AAesp03a.gif 76.2 KB Views: 15 AAesp05.gif 47.3 KB Views: 9 Last edited: Aug 7, 2014
