- Joined Jan 23, 2018
- 28,205
OK, Max, go back and look at the photo in post #18. Along side of the coil are three legs of steel,with a thick copper sleeve brazed around the center leg. The read my comments following about the massive shading coil. it does not look at all like the shading coils we are used to seeing, does it??What is that supposed to mean??
A shading ring should be in the same plane as the main coil.
In a relay for e.g. it is usually a single ring on top of the main coil.
Never at right angles to the main coil.
Relay e.g. (red arrow indicates it)
