I'm a little confused about something. I just recently finished a differential amplifier project and was looking back over the simulation when I noticed that the output voltage swing was centered around 5 volts. Is that what DC offset is?
I was just reading in the online book, "The amplifier is still being supplied with 30 volts overall, but with the split voltage DC power supply, the output voltage across the load resistor can now swing from a theoretical maximum of +15 volts to -15 volts, instead of +30 volts to 0 volts. This is an easy way to get true alternating current (AC)..." (Ch.8, Sect. 2; OpAmps)
In my diff amp, I was using +10 and -10 volt supplies. How could I center my output around 0 so that I could get a bigger voltage swing? Or is that even possible in a simple 2 BJT diff amp design?
I was just curious about that, it's not crucial for me to know.
