AC or DC/Active or Passive piezo buzzers?
Audioguru again
Joined Oct 21, 2019
6,826
The Piezo Element has a sealed enclosure so it will produce only the resonant frequency of 2048Hz. They say AC but usually those beepers have an oscillator inside and operate from DC.
The horn is an AC speaker but usually a piezo horn sounds awful. A few frequencies will be loud.
A 555 produces a rough-sounding squarewave.
Alec_t
Joined Sep 17, 2013
15,158
Are they AC or DC/Active or Passive piezo buzzers?
According to the M&G advert they expect a supply of 1.2-2.5 V AC .
According to the linked Hitpoint datasheet in the M&G advert they need a 1.25-2.5 V DC supply.
Take your pick. My guess would be DC. If it's DC then there is likely a polarity indication moulded into the plastic housing.
Audioguru again
Joined Oct 21, 2019
6,826
A Piezo horn tweeter produces some loud resonant frequencies but also produces some frequencies that are not loud. You need to tune its frequency for it to be loud.
It sounds like a high pitch beep, not like a siren.
Audioguru again
Joined Oct 21, 2019
6,826
The piezo horn speaker will not work being driven with only one transistor because it does not have a coil, it is a capacitor. The 555 can drive it but with a supply of only 5V it will not be loud.
sghioto
Joined Dec 31, 2017
8,756
I read the speaker can be driven by a single ended signal 0 to 5 volt or a bipolar signal. The specs rate the speaker at 8 or 4 ohms.
Audioguru again
Joined Oct 21, 2019
6,826
A piezo tweeter cannot be driven by a single-ended signal but works when it is parallel with a resistor or the coil of a woofer.
The specs rate the woofer speaker with 4 ohms or 8 ohms so that the piezo tweeter can match the loudness of the woofer.
Audioguru again
Joined Oct 21, 2019
6,826
The output of an audio amplifier or a 555 is push-pull, not single-ended. Then the parallel resistor is not needed.
With a 5V supply, the output of an NE555 is only about 3.6V so the piezo will not be loud.
Audioguru again
Joined Oct 21, 2019
6,826
I do not know if an output resistor to +5V will pull-up the output of an old NE555 or old LM555 to +5V. If it does then the +2.5dB will barely be noticeable.
sghioto
Joined Dec 31, 2017
8,756
Agree, not much volume with a 5 volt supply but that was just an example. Depending on what the TS requirements are there other options.
cmpx
Joined Oct 23, 2021
60
I don't have 2SD882 I use MJE13007 instead.
If I connect R Base 100R horn does not work?
The Max voltage is 35 V for horn.
How to connect an inuctor to this circuit?
What inductivity should it be?
PIEZO horn KHS 106
Code:
ZV-KHS106
Specification:
300/150 W , 2-20 KHz , 90 dB
Technical specification:
Dymensions: 95 mm
Music power (4 Ohm) : 300W
Music power (8 Ohm) : 150W
Frequency range: 2000 - 20000 Hz
Sensitivity: 90 dB
Max. voltage: 35 V ~
resistor
I added a trimmer resistor from 0 to 100K.
be loud.
What induction coil I need to use for Horn?
I use MJE13007G.
If I connect trimmer R to Base and set it to 100R value horn will not work.
I set trimmer R on Base to 1K.
