Does a Linear Active Diode Run Cooler than a Passive Diode?
38,931
Will linear active diode like this run cooler than a passive diode? Or is it just to eliminate the voltage drop?
https://www.allaboutcircuits.com/video-tutorials/op-amp-applications-active-rectifier/
It does both.
Reducing the voltage drop, reduces the power dissipation for a given current, which thus would allow the device to run cooler (assuming they both have about the same thermal resistance to ambient).
Edit: Correction. I was mistakenly talking about an ideal rectifier circuit, not the active rectifier circuit in your reference. The active rectifier will dissipate the same power for the same current as a normal rectifier.
38,931
But it will run cooler than a passive diode?
The switched-MOSFET will.
Below is the LTspice sim of a switched-MOSFET rectifier versus a silicon-junction rectifier for a 1A peak rectified current:
The N-MOSFET is switched on (yellow trace) for the negative have cycle of the supply voltage (blue trace) to perform the low drop rectify function.
The forward drop of the MOSFET (pink trace) is 76mV while the diode drop (purple trace) is near 1V
This gives a diode peak dissipation (white trace) of near 1W, and a MOSFET peak dissipation (orange trace) of <76mW.
schmitt trigger
Joined Jul 12, 2010
2,279
To complement Crut’s excellent answer, the ideal diode will generate less power losses for the same forward current.
Whether it will run cooler, depends on the thermal resistance from junction to ambient. In other words, how well the device can dissipate the heat.
38,931
My question is about the linear op amp active rectifier in the article.
And as I previously noted (why do I need to repeat this?), the dissipation in the active rectifier diode is the same as the normal rectifier at the same current.
All the op amp does is reduce the diode offset in the output by a factor equal to its open-loop gain.
BobTPH
Joined Jun 5, 2013
11,674
But isn’t the opamp dissipating additional power? Correct me if I am wrong, but isn’t the current coming from the opamp output? And doesn’t it drop the voltage between its supply and the output?
38,931
Of course.
But did you not read the TS's first post?
The question was only about the diode dissipation/temperature, not total power.
BobTPH
Joined Jun 5, 2013
11,674
That is one possible interpretation. I took “linear active diode” to refer to the whole circuit, not just the diode.
In any case, assuming a typical op amp that can output 20mA t most, the diode ain't gettin’ all that hot.
johnyradio
Joined Oct 26, 2012
615
I asked: "Will linear active diode like this run cooler than a passive diode? Or is it just to eliminate the voltage drop?"
You replied: "It does both."
I see you went back and edited your answer later. Not fair to be annoyed that i missed your later edit.
My question is about the entire circuit, not just the diode.
Yep. In usage, the entire active diode replaces the passive diode, so a meaningful comparison looks at heat of the entire circuit.
Although, this op amp based circuit might not be practical for my purpose anyway, since my load wants 3A. If this requires an op amp that can deliver 3A, then i cannot find an op amp that can do that.
So losses are lower, but heat depends on device dissipation. In the linear circuit, do you mean dissipation in the op amp or the diode? If it's the same diode as used in the passive rectifier, then if losses are lower, then heat must be lower too, right?
BobTPH
Joined Jun 5, 2013
11,674
The diode carries the same current, so it alone dissipates the same power as the simple diode circuit. But that same current goes through the op amp, so it also dissipates power.
Also, the power is coming from a different place. Without the opamp, it is coming from Vin, with the active circuit it is coming from the supply to the opamp.
38,931
No it would not.
The reason for the precision rectifier circuit is to eliminate the forward-drop voltage of a diode in signal processing applications.
It makes no sense to use it for 3A in a power application, as there's no advantage, and it would just dissipate more power.
If you want to rectify 3A with minimum loss, then you would use a switched MOSFET ideal-diode circuit.
