Do you think this PSU comes with active/passive PFC ?
p699
Joined Oct 8, 2021
40
I have come to believe that a PSU which has no voltage selector at the back and can operate from 100Vac to 240Vac most probably has PFC circuit inside. I dont know how true this assumption is (not true for mobile chargers) but all the ATX SMPS I have with me are like this.
There is a seconds sale of a particular PSU right now, I am thinking of buying it in some quantity. But I am not able to know if it has PFC or not. No documentation seems to be available online. Can you please look at the attached photos and guess if it contains a PFC circuit ? Based on some photos I found online I know it has this ic TNY277, I dont know if it is for PFC or not.
Screenshot 2024-11-23 at 21-59-38 (2) Convert SMPS into Dc 12v Computer power supply Convert D...png
Ian0
Joined Aug 7, 2020
13,315
As it is CE marked, it must meet EN61000-3-2 (Harmonic Currents), which have reasonably strict limits for computer equipment (not as strict as lighting) so, at a guess, it will have some sort of power factor correction.
However, it is perfectly possible to make a flyback converter without PFC that operates from 90V to 250V.
TNY277 has a maximum output of about 20W, so that's not the main controller chip.
Papabravo
Joined Feb 24, 2006
22,115
TNY277 is just a switch with a feedback input for undervoltage on the output of a flyback converter. There is no mention of doing PFC in the datasheet. At least none that I could find.
Pyrex
Joined Feb 16, 2022
575
Output is 210W, so when powered from 240V current is expected to be about 1 Amp.
Input current on the table is 2.5 Amps so no PFC provided
Ian0
Joined Aug 7, 2020
13,315
It belongs to class D "Personal computers. . ." so its maximum 3rd harmonic current is 3.4mA per Watt of input, so I think it would need PFC.
p699
Joined Oct 8, 2021
40
Some ATX-PSUs come with no PFC. I have a few of them. I have compared both, the non-PFC one pulls 25% more current for the same task executed on the same computer. This thread originates from this dilemma. If I can have PSUs with PFC then I can buy smaller UPS and thus save some money.
Ian0
Joined Aug 7, 2020
13,315
It might take more current, but does it take any more power?
