AC motor soft start. Surprised there's not a simple solution
Robin66
Joined Jan 5, 2016
281
Lets know the results. ;)
Max.
Ok this has taken way longer than I expected but I'm declaring this a success. It's not perfect but it's pretty good. The updated schematic is below
  • I've regulated the tablesaw to ~50% of the no load speed
  • It has soft start and gets to the target speed in ~2secs, with a little overshoot.
  • Under heavy load (cutting 40mm oak) it takes ~1sec to max out and engage the relay
  • The TRIAC doesn't get hot enough to warrant a heatsink
  • Speed is determined by measuring the current 500us before mains zero-cross
  • I used a PD control algo
What would I do differently?
  • Control the relay by sinking current from the PIC, since max Isink ~2* max Isource.
  • Add a push button to aid debugging/tuning
27,947
It certainly looks like a good package, and from the description it appears to be meeting your needs, so that is great! Thanks for sharing the results! The long extension cord would have provided the soft start but it would also have had poor speed regulation. It is a cheap trick for some kinds of emergency situations, not at all efficient and far from optimum performance. But it did work once on a farm.
That is better than the table saw with a high powered induction motor, which has a large starting inrush and won't even run on a cheaper engine driven generator, although the numbers said it should.
I designed a similar system for soft starting power amps up to 2000watts.
It worked very well.
I just dropped mains through a resistor and diode into a capacitor then 5V1 zener for PIC power.
The opto isolator doesn't need much current.
Robin66
Joined Jan 5, 2016
281
I'm guessing you omitted the relay which requires ~30mA, or you used a ~10W resistor
