Identify whether or not the mixing network is series or shunt. If the signal source
has one terminal on ac ground then:
a.) If the input active device has one of its input terminals on ac ground, then the
mixing network must be shunt.
b.) If the signal and feedback sources are applied to different input terminals of the
input active device, then the mixing network is series (this includes differential
amplifiers where two devices form the input active device).
when they say "if the signal has one terminal on AC ground".what is AC ground?
