How did you measure this? There is almost no possibility this is correct.Hi. I measured electricity frequency as variable between 50-800 Hz. Does it cause any problem in my home?
THe way that AC power is generated requires the frequency be maintained within a very small range, about ±1Hz.I measured it with multimeter
There is no mechanism for your mains to have a frequency other that 50Hz with a < 1Hz variation. There is an absolute requirement the generators creating the power stay in the range and nothing between you and them that could shift ithe frequency.I mesured 1 phase as 50Hz stable and 1 phase varying 50-800Hz.
Sounds like your meter isn't reading it correctly, what country are you in?I mesured 1 phase as 50Hz stable and 1 phase varying 50-800Hz.
I highly doubt that.My water pumps broken due to that I measured frequency.
I read it as the pump is broken, so that's why he's probing around and seeing the odd frequency reading.High frequency noise on the line may be causing your bogus meter readings.
What makes you think that's what caused the failure?
Probably noise, not necessarily an open circuit. To get a proper measurement on a noisy circuit it would be best to use a low impedance meter. Either an analog meter or a DMM with low-Z modePerhaps one phase is open and he's seeing noise pickup (but no power). Or is this a 3 phase circuit?
what meter do you have to measure frequency ?I mesured 1 phase as 50Hz stable and 1 phase varying 50-800Hz.
That's why at school they still teach to put commas somewhere in sentences.I read it as the pump is broken, so that's why he's probing around and seeing the odd frequency reading.
I live in Turkey, I opened circuit breaker and measured only network side, it was 50 HzSounds like your meter isn't reading it correctly, what country are you in?
Pump broken, then I tried to investigate source of the problem I saw the frequency was unstableI read it as the pump is broken, so that's why he's probing around and seeing the odd frequency reading.
If the circuit has failed open, perhaps he's seeing an artifact such as EM from fluorescent lights.
I measured with multimeter VICTOR VC97.what meter do you have to measure frequency ?
