AC frequency is more than 800Hz
Ya’akov
Joined Jan 27, 2019
10,368
Also, if you actually had such a situation, very few of your household appliances simply would work, if any at all, and things with motors like refrigerators and air conditioners would make it very clear they were unhappy, so absent screeching, fires, and failures—your meter is not working.
wayneh
Joined Sep 9, 2010
18,184
High frequency noise on the line may be causing your bogus meter readings.
I highly doubt that.
What makes you think that's what caused the failure?
I read it as the pump is broken, so that's why he's probing around and seeing the odd frequency reading.
If the circuit has failed open, perhaps he's seeing an artifact such as EM from fluorescent lights.
strantor
Joined Oct 3, 2010
6,875
Your power comes from a rotating machine somewhere. That machine is spinning 3,000 RPM (maybe 1,500RPM) to deliver 50Hz. In order for it to deliver 800Hz, it would have to spin 16 times faster, 48,000RPM. Even if you receive power from a nuclear plant in runaway condition, I doubt it could spin that fast without flying apart. All the transformers on poles would be exploding around you. In other words, you are not receiving 800Hz power. Your meter is lying to you. They do that sometimes, especially the cheap/crappy ones.
josepars
Joined Nov 28, 2018
73
Pump broken, then I tried to investigate source of the problem I saw the frequency was unstable
Deleted member 115935
Joined Dec 31, 1969
Thank you,
What I think is happening, is to do with the meter.
It looks a lovely meter,
but I wonder how it measures frequency ?
If the input was say a nice square wave, it could time between two rising edges, to give a frequency,
same would work for a nice sine wave, as in perfect AC mains.
BUT
The real AC mains, is going to have lots of spikes on it, like this,
now what is the meter to do ,
it measures between rising edges,
in this case its going to read 6 times the real frequency
what happens if it has two spikes, quiet close,
the it would measure these as the frequency , and could be very high.
You really need to look at the quality of the signal,
which is a scope job,
if its a nice sine wave, then the frequency meter is fine,
if it has spikes, then the frequency meter is not of much use.
