AC-DC power supply repair.
Davizuco
Joined Jul 12, 2018
32
I am trying to repair an AC-DC switching power supply with my basic knowledge of electronics. (220 v AC to 34v and 12v DC)
The problem seems to be the MOSFFET (10N60c), It shorts and then the fuse, a capacitor and some resistors blew.
It seems like I would be able to fix it, but the SMD resistors are so bad that I can't figure out their value.
There were 5 resistors between the Mosffet source pin and ground, all of them melted and I can only see the first and last digit (1?0 , may be 120, 180, 100 or whatever) I guess they all have the same value.
The power supply uses a LD7575PS to drive the transistor.
can anyone help me find the correct resistors?.
dl324
Joined Mar 30, 2015
18,463
There are 5 resistors in parallel. My guess is that they're 1R0, but could also be something like 180.
You're playing with fire. Lethal voltages are present.
The problem seems to be the MOSFFET, It shorts and then the fuse, a capacitor and some resistors blew.
The actual problem could be downstream from the MOSFET.
Davizuco
Joined Jul 12, 2018
32
Yes I know, it is around 300v in that part of the circuit, I took precautions by discharging the capacitors and watching where I put my hands. Thanks for the warning.
Definitely the problem was caused by the Mosffet, it is completely shorted, I already have a replacement.
Dodgydave
Joined Jun 22, 2012
11,395
Switch-mode psu, current sense resistors in series with the Source pin of the Mosfet, probably 1R0 , there must be something else that's causing the over current situation.
Can you check them with a multimeter?
Davizuco
Joined Jul 12, 2018
32
How do you know if that's the cause, or a result of the real problem?
ahh okkk sorry, I didn't understand what you mean. I don't really "Know" 100%.. but everithing arround looks ok (diodes, resistors, etc.. ) but mosffet and it's source resistors are melted, just guessig
Davizuco
Joined Jul 12, 2018
32
My multimeter can't check 1 ohm resistors, to small for it... almost I think it can´t
Davizuco
Joined Jul 12, 2018
32
My multimeter tells that they are shorted, if that is what you are asking for. Same result as putting both probes together.
BobTPH
Joined Jun 5, 2013
11,645
The MOSFET is most likely to put a pulse of current into an inductor. If it remains on longer than it should, the current goes too high and it burns up. So whatever is controlling the gate, likely s SMPS controller chip might be culprit. Or any of the inputs to it. Like the output voltage feedback, which is usually through an optocoupler. Many possibilities.
