DickCappels
- Joined Aug 21, 2008
- 10,662
You are indeed welcome.
I am impressed! That waveform looks much cleaner than I expected it to look!
By the way, if you need more amplitude you might want to increase your shunt resistor. Right now you are loosing about 65% of the shunt voltage in the 40.1 ohm secondary winding of the current transformer.
Congratulations -you now have a current waveform you can work with!
