AC constant current source
Ch.praveen
Joined Jan 5, 2017
4
Hi .. Good afternoon to every one.
I want to design a AC constant current source with the following parameters
1mA current
50KHz frequency
Load variable upto 100 kilo ohms.
Please help me which circuit is helpfull for me
Alec_t
Joined Sep 17, 2013
15,171
Welcome to AAC.
Is 1mA an RMS or peak value?
What tolerance?
Is a square-wave output satisfactory or must it be sinusoidal?
If sinusoidal, what harmonic distortion level can be tolerated?
What will power this (since 1mA through 100k implies at least 100V somewhere)?
What is the lower limit on the load resistance?
Ch.praveen
Joined Jan 5, 2017
4
Hey thanks for reply
Current is 1mA peak value
with +/_ 5% tolerance and the output should be sinusoidal
And lower resistance is 5k
Alec_t
Joined Sep 17, 2013
15,171
What devices will this 1mA drive?
Is this for some medical/health treatment/monitoring gizmo? If so, safety features would be necessary.
Motanache
Joined Mar 2, 2015
652
For example here is a source of constant current in DC:
This it offers constant current with a value given by the resistance R2.
You make that R2 resistance to be something dynamic, to say a tranzistior.
This second transistor will be drived by sinusoidal signal.
It's just an idea, not negative current value.
Motanache
Joined Mar 2, 2015
652
I tested the following circuit in simulation and it looks like it works:
R1 is the load.( a constant maximum value sinusoidal current will pass through R1, whatever the value of R1 will be. Of course within certain limits)
R2 should be a resistor with resistance as small as possible which is used to read current (few ohms or milli ohms).
It works as long as the output signal remains sinusoidal.
It works as a current source (alternating signal).
It is actually negative feedback operational amplifier, modified to respond in current, not in voltage.
1mA at 100Kohm it means 100V half the of minimum supply voltage.This is strange.
1mA current
50KHz frequency
I don't think you can buy an op-amp with a power supply range of +/- 100 volts. You're going to have to put a driver circuit on the output of that amp in post #9 and the slew rate is 31.4 v/usec. Again, not an off-the-shelf product. This looks like a job for a high frequency transformer, or an imaginary solution to a problem that should be solved in a different way.
HW-nut
Joined May 12, 2016
97
High Voltage Power Operational Amplifiers
Apex introduces PA34x series high voltage monolithic MOSFET OP AMPs
+/- 350v available
Marley
Joined Apr 4, 2016
519
Because this application is a constant frequency and sinusoidal, can this be done with a L-C filter circuit? Or at least approximated.
I am thinking of a series resonant circuit where the voltage at the junction of the capacitor and inductor is a very high impedance at resonance and generates a very high voltage when not loaded.
Basically, a constant current source has a very high output impedance (ideally infinite).
I am thinking of a fairly low voltage but reasonably low impedance source (a small integrated power amplifier, say) driving this series resonant circuit, perhaps with some kind of feedback to regulate the drive amplitude.
hp1729
Joined Nov 23, 2015
2,304
Put it inside a bridge to make it AC.
