About standard test signal .....
Rohit156
Joined May 18, 2018
11
Why unit area or unit impulse,step,ramp,parabolic test signals are distinguishably standardized? can you throw light on this, it will be helpful .
Papabravo
Joined Feb 24, 2006
22,082
Would you prefer some other constant be used for a standard? In some cases the choice is purely arbitrary. The unit impulse has a definition that CANNOT be realized in practice. Approximated, but not actually realized.
Delta Prime
Joined Nov 15, 2019
1,311
Hello there :)
Believe it or not light is a standard.
The speed of light in a vacuum is 299,792,458 metres per second, a figure scientists finally agreed on in 1975 - but why settle on that figure? And why does it matter? Answering those questions takes us through space, time, physics and measurement.:)
Rohit156
Joined May 18, 2018
11
Give us the context. That may help with providing an appropriate answer.
Thanks for you response!
During studies of signals & system, I wondered, why especially unit area for any test signal are taken into consideration? Is it related to mixed signal processing , so that it will be easier to handle mathematically?
Rohit156
Joined May 18, 2018
11
I wanted to know , what will be the generilzed case in that context that prefered(effective) in system testing.
