AAC Upgrade Thread - Feedback & Bugs
Status
Not open for further replies.
ScottWang
Joined Aug 23, 2012
7,505
So far the one thing that I miss is in profiles, where before I might see that somebody is a student, or claiming to be an engineer, or a Maker. Now that is gone, it appears.
Can you find the Information of the member whom you want to see the profile?
Like your Information is Other Engineer Type.
djsfantasi
Joined Apr 11, 2010
9,237
It seems that the buttons on the reply editor are all grayed out? I went to create a link and that didn’t work. Same for bolding text, Changing alignment, making a bulleted list, etc..,
bertus
Joined Apr 5, 2008
23,006
As far as I know, the buttons are activated.
The system seems to remember if you pressed the "Toggle BB code" button.
Bertus
28,320
PLEASE give us back the tool to insert Greek and math symbols simply, without having to learn Latex or jump through other hoops. Those symbols are essential to many circuit discussions.
I found the text editing tools far better than the Home depot product comment editing tools, at least 40dB better, really. And the lack of symbols and special characters is why I spell out a lot of things. I had not expected them to be available. So I will hold all comments about the changes until enough time has passed that I can know what I am talking about. So far, the big relief has been to know that it was something that I did wrong, or some malware getting ready to spring.
Mark Hughes
Joined Jun 14, 2016
409
It seems that I had not been familiar with what needed to be changed, and I was not aware of flaws or defects. I have seen that folks were able to post files from programs that I was unable to open, but that was obviously my problem, not theirs, because it was the simulation programs that produced those files. so I do not complain about that.
I don't know anything about AAC's backend -- but I used to be responsible for some other servers and I hated every minute of it. So -- code bases evolve over time -- even if you don't add one bit of increased functionality to your website, the constant security releases, patches, upgrades of the underlying server software will break your website over time. So you constantly have to edit code / hack / patch your website software to try to keep your website working. It ends up being a kludge. At some point, either critical functions are deprecated or it's such a mess that it just makes sense to backup all the user information, hit Ctrl-Alt-Del on everything else, and start brand new with the latest version of the software and begin the process of coding / hacking / patching all over again.
OBW0549
Joined Mar 2, 2015
3,565
I miss that feature too, but found a workaround.
On the Mac, those symbols can be typed by a combination of the Alt/Option key and various other keyboard keys. Option + m gives the µ symbol; Option + z gives Ω; Option + p yields π; and so forth. I made a cheat sheet that lists various useful combinations.
That works OK, but I decided to go one step further: I changed the cheat sheet into a .html file and put a link to it in the bookmarks bar in Chrome. Now all I have to do is open that file in a separate tab, select and copy the special character I want, and then paste it into the AAC edit window.
The html code for this file is:
HTML:
<HTML>
<CENTER>
<head><title>SYMBOLS</title></head>
<BR>
<BR>µ
<BR>π
<BR>√
<BR>Ω
<BR>∆
<BR>≈
<BR>≠
<BR>∞
<BR>•
<BR>÷
<BR>°
<BR>∑
<BR>Ø
<BR>™
</CENTER>
</HTML>
For me, this works as well as, or better than, the "S" symbol popup that we've been used to here.
28,320
M.H. , Thanks for the explanation. I am not a software person except for PLCs, and writing the functional requirements of code so that others can understand what a program must deliver. My presumption has been that "code does not break", nor does it wear out. And so I am suspecting that my assertion that the computer driven cars must be set with perfect code on day one is not asking for anything close to possible. But I would not want to own a car that needed 200+ Meg of fixes every week.
Papabravo
Joined Feb 24, 2006
22,111
I just did the registry change to allow direct keyboard input of Unicode. It works for entering Greek letters and special symbols on this site and also in LibreOffice.
https://en.wikipedia.org/wiki/Unicode_input
  1. Open Regedit and navigate to HKEY_CURRENT_USER\Control Panel\Input Method
  2. Create a new key of the String type (REG_SZ) named EnableHexNumpad
  3. Set the value of the new key to a 1
  4. Exit Regedit and reboot
When the machine comes back you can get the Greek letter alpha by holding the Alt key and typing + on the numeric keypad followed by 3B1 and you get --> α
If it works for you you have the whole Unicode character set.
joeyd999
Joined Jun 6, 2011
6,456
Funny. Linux understands Unicode by default.
You MS guys have no idea how limited your world is.
DickCappels
Joined Aug 21, 2008
10,661
OBW0549's solution is brilliant (in the classical sense)!
If you have trouble putting OBW0549's HTML code into a document with the extension "html", you might want to use a copy of it on the web. Perhaps somebody can find a more "permanent" hosting service.
cappels.org/symbols.html
Status
