AlbertHall
- Joined Jun 4, 2014
- 12,653
Much better, but you have a resistor in the battery negative lead which should be a direct connection.is that better?
Also note that the power supply needs to be able to supply the input current and the relay current for each channel. That is (11 channels) * ((20mA input current) + (70mA relay current)) = 990mA. You should allow a margin above that so 1.5A as a minimum.
