A replacement for this IC part?
Khaleef
Joined Mar 22, 2017
120
I have a problem with a Romoss powerbank which I bought. It was working very well just few days ago, I stopped charging my device and would not charge itself instead, a part of it heats up very much.
I opened the powerbank to see if I could do the fix. I noticed when I plug the Powerbank in AC, there's this small IC (IP1689) that heats up very bad and when I read the Input Charging USB port Negative and Positive with a Multimeter to check resistance, it beeps which means they are bridged together. Then I removed the IC from the PCB and the bridge stopped but with no resistance. I can not find the part to order or get support from the manufacturer.
I would like to know if there is another way or jumper to work around the IC to make the Powerbank work.
Thanks
(Attached is the image of the PCB and the Part)
hp1729
Joined Nov 23, 2015
2,304
Thanks
Can you find a manufacturer's logo on the chip?
Khaleef
Joined Mar 22, 2017
120
Thank you @Jony130 I have checked the link but didn't find the IP5189 but I have mailed them my problem and asked if they could help me as an end user!
Is there any other thing I can try should they not agree to provide any help?
Thanks again!!!
Khaleef
Joined Mar 22, 2017
120
Hello , I didn't get a reply from Injoinic concerning my problem! I was thinking they didn't want to give out the part. What else can I try please? I need the Powerbank working. It's very expensive to just let go.
Khaleef
Joined Mar 22, 2017
120
Thanks @absf
How do I go about it please, would they have to agree selling the IP5207 to me or there's something I can do with the datasheet?
Thanks.
MisterBill2
Joined Jan 23, 2018
27,519
Thanks
If there were a way to make the system function by means of bypassing that IC, certainly the producers would have used that method of making it work.
Thus, bypassing the IC will not provide the similar operation, but we have no hint as to what functions will be missing.
Khaleef
Joined Mar 22, 2017
120
I think that chip is a main Powerbank module and supports the QC protocol which there are other models from the same manufacturer which doesn't.
I scrapped it a long time ago as I couldn't get the chip.
