I have a problem with a Romoss powerbank which I bought. It was working very well just few days ago, I stopped charging my device and would not charge itself instead, a part of it heats up very much.
I opened the powerbank to see if I could do the fix. I noticed when I plug the Powerbank in AC, there's this small IC (IP1689) that heats up very bad and when I read the Input Charging USB port Negative and Positive with a Multimeter to check resistance, it beeps which means they are bridged together. Then I removed the IC from the PCB and the bridge stopped but with no resistance. I can not find the part to order or get support from the manufacturer.
I would like to know if there is another way or jumper to work around the IC to make the Powerbank work.
(Attached is the image of the PCB and the Part)
