A question regarding Step Down Transformers
B Bobby
Joined Oct 6, 2018
8
I need to order a custom step down transformer to output 16v 12amp
Manufacturer asked me about input voltage.
My area has power fluctuation which ranges between 210v to 245v, I am confused what should be the target voltage for input 230v or 240v or something else?
thanks for your help.
drc_567
Joined Dec 29, 2008
1,156
... Your target power level is approximately 200 VI ... volt-amps. However, you should order a 500 VI rated transformer ... so that you avoid heating inefficiency. The secondary voltage should be somewhat greater than the 16 volt target voltage. A 24 volt secondary has a peak value of 1.41* 24= 34 volts, which is a little high. A 12 volt secondary transformer has a peak sine voltage of about 17 volts, which may work, depending on the target requirements. The secondary of the transformer will produce 34 volts or 17 volts after it goes through a diode bridge rectifier and electrolytic filter capacitors are placed at the input of a voltage regulator of your choosing. The target voltage of 16 volts is a little unusual, so you may want to get another opinion as far as voltage regulation goes.
... Can you provide additional information about the intended use?
B Bobby
Joined Oct 6, 2018
8
Thanks for the detailed answer I was looking to build a manual charger for Flooded Lead Acid (FLA) Battery , I need upto 14.8v to 15v to equalize them therefore I was in perception that a 16v Transformer will work, Of course combined with bridge rectifier +Capacitor + Constant current Constant Voltage module
(I will buy off the shelf modules and just connect them together this is where my skills end)
Hymie
Joined Mar 30, 2018
1,347
If the thread starter is after 12Vdc at 16A, there are plenty of switch mode power supplies that will do the job.
B Bobby
Joined Oct 6, 2018
8
But my google searches suggest that a transformer based power supply is recommended for charging large FLA batteries that is why I was interested in transformer based solution. Can you please give your opinion about it?
Hymie
Joined Mar 30, 2018
1,347
No, a 16V transformer will give a peak of 22V after rectification – too much to charge a 12V battery; unless the Constant current Constant Voltage module can handle this.
drc_567
Joined Dec 29, 2008
1,156
... Charging lead acid batteries can be problematic sometimes. Leaving a constant current charging on the battery can lead to internal damage of some sort. ... If you want to be sure that charging is done correctly, leading to longer battery life, consider getting one of these devices ... used one for several years ... no problems.:
https://www.google.com/aclk?sa=L&ai...wj9oPONn4zgAhUDna0KHf5VDQ4Qwg96BAgYED8&adurl=
... don't know if they can be used on multiple batteries in parallel ... inquire to the manufacturer.
B Bobby
Joined Oct 6, 2018
8
... Charging lead acid batteries can be problematic sometimes. Leaving a constant charging on the battery can lead to internal damage of some sort. ... If you want to be sure that charging is done correctly, leading to longer battery life, consider getting one of these devices ... used one for several years ... no problems.:
I have one of these smart chargers but they can't be used to revive dead batteries
"Why smart and automatic battery chargers SUCK. manual charger may be better"
Hymie
Joined Mar 30, 2018
1,347
In my experience, once a vehicle battery has reached the end of its service life – it cannot be resurrected, Lazarus like, by applying some voltage/current.
B Bobby
Joined Oct 6, 2018
8
More often than not, a dead battery is just that, dead, and cannot be revived.
Sometimes smart chargers simply refuse to charge a battery which somehow went below a certain threshold, one such incident can clearly be seen in the youtube video I attached above , this is where a manual charger can help to save such battery
Can you abuse the battery chemistry with a manual charges to the point where some parts of the plates might reactivate due to hard sulfate flaking off due a few hot spots excessive heat? Yes, you can but it's crippled for life, with a hair trigger for death, not saved.
Hymie
Joined Mar 30, 2018
1,347
One of my earliest electronic projects was a PSU rated up to 30Vdc, 4A. Before its demise, I occasionally used it as a car battery charger (normally set on constant current).
But once a battery was dead, it was dead no matter what voltage/current was applied.
drc_567
Joined Dec 29, 2008
1,156
For a secondary transformer voltage of 12 VAC, giving a rectified, filtered voltage of 17 volts DC,.. A voltage regulated, zener diode circuit, producing 15 volts at 10 amps, is shown here:
https://www.electronics-tutorials.ws/diode/diode_7.html
A 15 volt zener regulating diode resulting in 15 volts regulated output, is available here:
https://www.digikey.com/product-detail/en/microsemi-corporation/1N3314A/1N3314A-ND/4377747
... The resistor, R, used in the circuit is calculated to be 0.20 ohms, and should handle at least 20 watts... due to the 10 Amp current specification
... A 0.2 ohm resistor @ 30 watts is listed here:
https://www.digikey.com/product-det...onics-inc/MP930-0.20-1/MP930-0.20F-ND/1284411
... You will have to install the zener diode in a metal heat sink, making sure that the negative end connects to the + voltage ... that's the way zener diodes work. Wear your full coverage safety glasses in case one of the batteries is a little touchy ... accidents can happen. ... suggest not leaving a battery connected to this circuit unattended. ... hydrogen gas can build up leading to an explosion. ... an experience that should be avoided.
35,193
Good advice well worth heeding. I would go so far as saying no battery should be left on a charger unattended, smart or otherwise.
I can show you photos of what happens to a SLAB when the "smart" charger fails to terminate charging.
If you want hear personal horror stories about batteries exploding in your face just ask @recklessrog.
