A new (to me anyway), very nice, momentary switch...
Ya’akov
Joined Jan 27, 2019
10,297
Just received an order from AliXpress of some unusual membrane switches which I am very impressed with.
They come in a variety of styles, with 1, 2, 3, and 4 button configurations. The switch itself is a membrane type dome switch. They are surface mount using a self-adhesive backing and are only 1mm thick, so very unobtrusive when mounted and taking up no space at all inside the case.
I got the grey ones, but there are four colors (and a numeric keypad) available. I have subsequently ordered more colors.
1650964748472.png​
The leads are flex PCB terminated in .1" (2.54mm) female headers which is very convenient. Mounting is simple and clever. A ¼" (6mm) hole allows the connector through the panel, the gap the left side of the cable (in photo) is enough to completely cover the hole. The appearance is very neat.
A quick test shows they are relatively low bounce and the construction suggests that if they are not waterproof, they would still be quite water resistant.
Of course I don't know about longevity yet, but they seem robust and are very inexpensive. I ordered more in case they were no longer available when I needed them.
MrSalts
Joined Apr 2, 2020
2,767
Is it a dome switch
- a stamped piece of sheet metal that is soldered to a rigid PCB - the spring action of the stamping creates a return spring for a momentary switching effect as the center of the switch plate to make contact.
or...
is it a membrane switch?
- a flex film circuit mounted copper (or conductive printed ink) side down over an FR4 PCB or a second flex circuit and sealed with some amount of air inside to create a return air spring to create a momentary switch
meowsoft
Joined Feb 27, 2021
666
What oscillocope model do you use ?
35,177
I received a large number of dome switches as samples from a manufacturer.
I have used them in my home projects by laying out the contact pattern on the PCB. I simply taped the dome switches on to the PCB with "Scotch" tape. They work very well.
MrSalts
Joined Apr 2, 2020
2,767
@MrChips I was going to say, they can be soldered, but, now that I think of it, they are available with peel-and-place adhesive and I saw one company offering them on a tape spool for automated assembly.
Ya’akov
Joined Jan 27, 2019
10,297
These are described by the seller as "membrane" but they certainly use a dome. The base part, though, is flexible so I think the flex PCB leads are part of a flex PCB with the contacts on it. I really like the way they can be mounted with effectively zero space needed behind.
When the additional ones arrive I might take one apart to see what the internals are like.
maxcburk
Joined Oct 23, 2018
Ya'akov,
I know this a couple months old but figured i'd chip in since I am an engineer at a <link removed>.
Even though a membrane switch assembly uses a dome it is still a membrane switch, this is due to the flexibility of the metal dome acting as a flexible membrane. The ASTM defines a membrane switch as "switches that have at least one contact that is made of or attached to a flexible substrate". So as long as something is flexing in the assembly, it is likely considered a membrane switch, but to more accurate, it has to be in a sandwhich of layers as opposed to a residing inside an enclosure (like an smd or thru switch). Read More info on membrane switches <link removed> which shows the various common layer stack ups of membrane switches, along with exploded animations to get a better idea.
<MOD: removed links>
Ya’akov
Joined Jan 27, 2019
10,297
Ya'akov,
Thanks. I was unsure of the taxonomy and didn't look it up.
