A gain and capacitor question
Atakan Şişman
Joined Dec 17, 2016
31
Hello everyone,
given me informations are Vcc, Re, Rc Rl Rsig R1 R2, ( ß, Vbe, Vt in transistor).
wanted: 1.mid band gain Vo/Vsig and Vo/Vi.
2.C1 , C2, C3 a 3-dB low freq of fl= 100Hz.
My question is that , is it important r1 and r2 in this circuit for V0/Vsig , Vo/Vi
How can i find Vi ?
34,807
Usually, one would assume that Rsig is small compared with Ri.
Hence Vi is the same as Vsig.
R1 and R2 are critical since they set up the bias point, i.e. the Q-point.
ian field
Joined Oct 27, 2012
6,536
Hello everyone,
How can i find Vi ?
Essentially; R1 & R2 are a voltage divider providing a rudimentary Vref for the base. With the emitter resistor, it plays a part in the quiescent collector current. that part of the circuit is an emitter follower - the transistor will try to keep Vre at vr1/r2 less Vbe. Since Re is constant; the collector current to maintain the set voltage is also constant.
Your input signal varies the notional Vref at r1/r2 to upset the balance just described and cause collector current to vary in accordance to device gain. The higher you make r1/r2; the less it loads the signal - but making them too high causes other problems.
