A circuit’s electrolytic capacitor was blown up while the fuse remains
abdulbadii
Joined Aug 30, 2017
91
How can a circuit Elcos be blown up while the fuse remains intact and the biggest one, 400V 110 uF is surely burst up?
What's the best explanation on this and how to determine the fuse max limit?
Edit: Elco imprint is read:
ltec
PET 8228D
there's sticker on which's read:
02H1-ROHS L2-28
Papabravo
Joined Feb 24, 2006
22,116
How can a circuit it’s Elco be blown up while the fuse remains intact and the biggest one, 400V 110 uF is surely burst up?
If I knew what an Elco was I might be able to help. Different components fail at different times for different reasons. There is no single answer to your question that covers all situations.
Alec_t
Joined Sep 17, 2013
15,167
It depends what the fuse was intended to protect, what the fuse type and rating are, and what caused the elco (electrolytic capacitor) to blow up. Internal pressure, rather than excessive current, can cause an elco to blow up.
abdulbadii
Joined Aug 30, 2017
91
Why if an Elco having white silica gums stick onto it which quite likely burst out of the casing, after being separated and measured, it has correct Farad value for capacity?
Where did actually white silica come from and how to definitively ascertain the good and faulty Elcos?
Alec_t
Joined Sep 17, 2013
15,167
The ESR (equivalent series resistance) of an elco often increases with age, so the normal rated current passing through the increased resistance causes above-normal heating which can increase the internal pressure enough to cause the cap vent to open (perhaps violently) and let the goo escape.
Measure the cap's ESR and check it's according to the maker's specification.
rsjsouza
Joined Apr 21, 2014
430
Indeed. Fuses/breakers in a house circuit are there to protect the wiring, while the fuses inside an equipment are rated to protect the highest current element of the circuit.
It also depends on what you call a "blow up"; in general it is a high intensity event that happens at a very short time which causes catastrophic and irreparable damages to a part or subsystem (the capacitor in this case). Fuses work by increasing their temperature to the point of rupture of the metal - an event that can be exceedingly slow depending on the nature of the fault. A transient, for example, may rupture or damage a number of parts in micro- or mili-seconds before the fuse even starts to become hot. Other events caused by slow degradation (as mentioned before) may bring the fuse to a warmer state but the weakest link on the chain might fail before that.
In all cases, it is interesting to know the rupture curve of the fuses you are using - some of them take several seconds to open at the rated current, for example (check here for one example)
38,948
A bad electrolytic capacitor (Elco?) develops a high leakage current which can cause it to overheat and burst.
The current necessary to cause this can still be well below whatever the fuse rating is.
The fuse rating is typically some value above (perhaps about 25%) the maximum current the device will ever use in normal operation.
Deleted member 115935
Joined Dec 31, 1969
There is an old saying on the lines of
"the circuit blows up, and that blows the fuse so you know something has gone wrong,"
In the case of the capacitor,
its gone bang, and then open circuit, so the fuse will not blow,
Different electrolytic have different life's,
these can be down in the thousand hour region for the cheap ones running at their limits / running hot.
thats life I'm afraid,
