9v solar panel and 12v battery?
jho659
Joined Jan 10, 2015
3
I have a fairly simple question. Will a 9v (0.5w) solar panel charge a 12v (7ah) battery? If so, will there be any defects? Will the battery only charge to 9v? Thank you for any help at all!
18,184
Short answer is no. You need to exceed the battery voltage to drive energy back into it. And a 12V battery should never be discharged to as low as 9V.
The longer answer is that you could use a DC-DC boost converter to get the voltage up high enough.
wmodavis
Joined Oct 23, 2010
739
It will if it provides enough voltage & current to do so. Research this: How much voltage and current are required to amply charge the specific battery you want to charge. Manufacturers data sheets of the pertinent components in question are truly your friend to help YOU find the answer to your question.
jho659
Joined Jan 10, 2015
3
What if I used them together with a charge controller? So that the battery would not discharge into the solar panel. Would that affect its ability to charge?
38,948
You either need:
A solar panel with at least a 15V output
or
A DC-DC converter to step up the 9V to 15V (but those have losses which will reduce the power from the panel).
A charge controller only regulates the charging current, it won't generate the higher voltage you need.
jho659
Joined Jan 10, 2015
3
You either need:
or
So with a DC-DC converter, would it just make it charge slower? And if I were to go ahead and use the solar panel and charge controller, what would be the effects?
I've also included a picture of the charge controller itself.
#12
Yes, a DC to DC converter will make the charging process very slow. You have already been answered, "What will happen if I use an inadequate solar panel and a charge controller". It won't charge the battery. If you don't believe this, harness a bunny rabbit to your car and tell him to pull you to the grocery store.
ian field
Joined Oct 27, 2012
6,536
I think its more like the bunny rabbit on a treadmill with up-gearing to the road wheels.
You could charge two 6V deep cycle golf cart batteries in parallel (with a regulator) and then discharge them in series for 12V. Or you could use two solar panels in series for 18 V and use a regulator to charge 12V
bwilliams60
Joined Nov 18, 2012
1,450
Either way, you are going to be waiting a long time for all this to take place. You might as well throw a coat of paint on the wall while you are at it and watch it dry.
MikeML
5,444
You really need a panel which will make an open-circuit voltage of ~18V.
With the existing panel, and a charge-controller that contains a step-up switching converter (most do not; they require that the panel voltage be ~ 1.5times the battery voltage), follow the following calculation:
A step-up converter is at best about 80% efficient. A charge controller might be 90% efficient while initially charging the battery.
o.5W stepped up would yield 0.5*0.8 =0.4W at the charge controller.
0.4W at the charge controller would get 0.4*0.9 = 0.36W into the battery.
At 12V, the charging current into the battery would be I=P/E = 0.36/12 = 0.03A
To get 7Ah into the battery, it would take 7Ah/0.03A = 233 h of bright sunlight.
You will get at most 8h of direct sunlight on the panel per day (unless you track the sun), so it would take 233/8 = 29 days of sunlight to charge your battery.
Clearly, you have not selected the right panel for the job...
MikeML
5,444
I have some of these. The open-circuit voltage of the HF panel is about 20V, which is just right for a 12V battery.
However, at 1.5W, it will still take days to charge a 7Ah battery. I = P/E = 1.5/12 = 0.125A
7Ah/0.125A = 56h of direct sunlight.
56 h of direct sunlight/8 h of sunlight per day = 7days.
A 15W 12V panel would be more like it... (or 10 of the HF ones in parallel ;))
