8v charger to 5v
how convert 8v charger to 5v to charge my phone
  • 200
    Votes: 0 0.0%
  • 200
    Votes: 0 0.0%
  • Total voters
    0
dl324
Joined Mar 30, 2015
18,386
You need to drop 3 volts with a voltage regulator, diodes, etc.
If it were me, I'd go to a second hand store and buy a 5V adapter for a couple dollars.
Reloadron
Joined Jan 15, 2015
7,893
While a 7805 would do I would just buy a 5 volt charger which a version made for either 120 VAC or 12 VDC cost about $5.00 USD I wouldn't bother converting or building anything. Amazon has a wide variety including 120 VAC, 220 VAC and 12 VDC flavors all under $10.00 USD and many under $5.00 USD. Considering under five bucks and I see the things everywhere including used in thrift stores for a buck I would not bother making a 8 volt unit into a 5 volt unit. I guess if I did I would use a simple LM 7805 Regulator.
Ron
