8 turns with 22 gauge coil .
Fmrx
Joined Jan 28, 2015
28
I tried to do a coil with 28 and 26 gauge never even flicked the fm band went slowly tuning still nothing .put my finger on out put feel a little heat which I know is working .ok I'll get straight to the point on the schematic it explains use 22 gauge for 8 turns for air coil .i tried this for 26 and 28 gauge never worked .do I need more turns as it's different swg ? I've spreaded coils closed them together not a thing .?
Fmrx
Joined Jan 28, 2015
28
what is the diameter of the coil supposed to be? that maters too.
Hi here is a picture of the coil with diameter he means a ball point pen which I don't have a clue in measurements there so I used a 8mm drill bit .and also tried a 4mm drill bit .
ian field
Joined Oct 27, 2012
6,536
Sounds like a Band II FM bug - there's quite a lot of those floating about the internet, some of them for kits with a PCB incorporating a spiral track inductor.
As someone else mentioned, the air coil diameter matters, and sometimes you also have to stretch out the turns for a specific length as well as diameter.
Fmrx
Joined Jan 28, 2015
28
H
i ian thanks for reply there .yea there seems to be same schematics on Google dunno if it's market crap or what .but thought I would give it a go see how it went i new soon as I felt the output it's working but getting that coil was beyond me .i stretch the coiled wide as while tuning no joy at all .on a picture what is the diameter I would use to correct that issue ive used a 8mm and 4mm bit no luck at all .
ian field
Joined Oct 27, 2012
6,536
H
If you transmit at 10.7MHz - they can't tune you out.
Fmrx
Joined Jan 28, 2015
28
10mhz is where I'm thinking its landed on lol .another 70megs upwards would be nice to know it touches that band .so what is the diameter for that ball point pen he used as I don't have one . For my 26 or 28 gauge . It uses 5-30pf in parallel with the 8 turn coil .
ian field
Joined Oct 27, 2012
6,536
The FM bug circuit usually has an RF transistor with a small capacitor from C to E (usually about 5pF), without that it probably won't oscillate at all.
Exactly 10.7MHz would put it in the IF strip - that's why it can't be tuned out.
Fmrx
Joined Jan 28, 2015
28
Spot on ian .i just double checked over that schematic there I did forget to put in the 4.7pf from colecter to the emitter .how did you guess it was that ?. I don't have a 4.7pf .if I put two 10pf in series I'll get 5pf should that work ?
Fmrx
Joined Jan 28, 2015
28
Must say never building a crap transmitter like that ever again .the audio was poor out of 10 im giving it a rating of 1 absolutely rubbish quality
GopherT
Joined Nov 23, 2012
8,009
Best thread ever. Excellent example of engineer-speak. "I know I didn't say what I meant but he answered my question so it was good enough"
Fmrx
Joined Jan 28, 2015
28
He answe
he answered the question yip .so as I saw it ripping through the whole dial I was like in the bin with that lol
Fmrx
Joined Jan 28, 2015
28
I understand the words they are using just fine. Not being a radio guy, I just can't figure how they all fit together into such an obviously complete picture.
Well imthTs the world of a emateur radio well thimeres a lot of good guys out there who give me good schematics there from amateurs there as much as a hobbiest as I am .
joeyd999
Joined Jun 6, 2011
6,361
Say again?
Edit: Sorry, your signal is breaking up...I can't hear you...
Fmrx
Joined Jan 28, 2015
28
Lol .swr must be going out the window .i was saying that's the world of amateur radio there your friends. And I was saying I have a few good friends on amateur radio .who do schematics for me as I'm a hobbiest and just like there hobbiest too and keen to learn new things
ian field
Joined Oct 27, 2012
6,536
For values up to about 10pF or so you can use a "gimmick" capacitor - two short lengths of insulated single core wire twisted together.
If you also have the means to measure signal strength - you can tune for maximum smoke.
