8 pin glass relay
Rangerover
Joined Aug 18, 2018
31
Im rewiring and upgrading my kids ride on car and for the life of me i cany get the relay to work for reverse. It all works in FWD although when you select REV it still goes FWD!
Here is my wiring diagram that i am using. Any thoughts?
dendad
Joined Feb 20, 2016
4,641
Have you tried just putting the motor onto the battery and than swapping the leads to make sure the motor is reversible?
Dodgydave
Joined Jun 22, 2012
11,395
Pins 7,8 are the relay coil i assume, so what happens if you reverse these pins?
Looking at the wiring, the relay has a set of change over contacts, but your relay maybe faulty.
dendad
Joined Feb 20, 2016
4,641
On your circuit,it looks like your coil is energized all the time as the battery is connected across the coil, if 7 and 8 are the coil pins. I don't know what the F/R block is.
Any forward/reverse switch needs to be in series with the coil, not cross it.
Do you have a relay type number?
Alec_t
Joined Sep 17, 2013
15,127
Pins 1 and 3 should never have continuity if the switch is indeed being used for reversing, but might have if the switch is wired for forward only.
AlbertHall
Joined Jun 4, 2014
12,636
From your diagram the coil is permanently connected to the battery so will always be energised so the motors will always run in the same direction.
Your forward/reverse switch should switch the power to the coil on and off.
Dodgydave
Joined Jun 22, 2012
11,395
Your relay is a Non latching type, so your wiring diagram shows the relay will only reverse direction when no power is applied to the coil, and forward direction with power on the coil,.
Same diagram here with power on wipers..
Rangerover
Joined Aug 18, 2018
31
Appreciate all the feedback and comments although i have no idea what im doing and surprised i have gotten this far with the project.
Can someone help with a diagram on how my relay should be wired so that Forward and Reverse will work?
Alec_t
Joined Sep 17, 2013
15,127
Try this :-
Caveats:
1) Suddenly reversing when the motors are running at speed will cause a big current surge, which the controller may object to.
2) Arc suppression capacitors should be connected across the relay contacts to prolong their life.
Rangerover
Joined Aug 18, 2018
31
So basically i just change my pins 7 & 8 to instead of having 4 wires in pins 7 & 8, i just have 2 wires incorporating the Forward and Reverse switch?
Rangerover
Joined Aug 18, 2018
31
Alec - are you able to explain this a little more? I have capacitors across the motors, is that enough or do i need a capacitor across the relay as well?
If not, What size capacitor do i need and across what pins?
Thanks
Rangerover
Joined Aug 18, 2018
31
So...
Pin 1 = is brown wire which loops to pin 4
Pin 2 = is other brown wire which loops to pin 3
Pins 1 & 2 are also connected to the battery output terminals of the controller
Pin 5 & 6 = wire motors
Pins 7 = GND
Pins 8 = pin2 of F/R and pin4 of F/R is connected to +VE (brown wire)
Pins 2 & 4 of F/R has continuity when R is selected
