8 bit to 3x7 segment display
WBahn
Joined Mar 31, 2012
33,123
Keep in mind that, in general, you have 12 output variables each with 8 input variables. Thus a table with 256 rows that you have to come up with the expressions for 12 variables.
Certainly it's doable. But likely to be very error prone.
I would hope that the problem constraints allow for a much more reasonable approach. But we need the TS to come clean and state the full and complete problem statement including what resources may and may not be used.
absf
Joined Dec 29, 2010
1,968
I think 10 output vars should be sufficient as the MSD of 255 is only 2 bits long.
I did one with EPROMs and I have to dig out the file so I can show the deadly spider.
Allen
absf
Joined Dec 29, 2010
1,968
And here's the EPROM version of 8 bit Binary to BCD converter. The smallest ROM I can find in proteus is 2732. The smaller ones are TTL PROM and serial eeprom which I have no ideas how to program them.
I'll attach the design and ROM hex files later in case someone wants to try it out.
Allen
dl324
Joined Mar 30, 2015
18,454
This was an interesting problem.
I designed a 4 bit binary to BCD converter and implemented a 5 bit converter. I decided to do 4 bits instead of 5 like the 74185 to keep the kmaps simple.
Sorry about the weird aspect ratio. Still learning how to use the capture program.
EDIT: Just noticed that I have the labels for the Q3 and Q2 sequence generators at the bottom of the screen swapped...
This doesn't give away any more than the NatSemi or TI datasheets:
dl324
Joined Mar 30, 2015
18,454
Interesting. I might program some EPROMs to do the conversion. I have some M27C4002 that are 16 bits wide, so it would only require one EPROM for 4 digits and wiring would be simplified because the address lines are on one side and the data lines are on the other.
Using logic gates would take a lot of wiring and real estate...
dl324
Joined Mar 30, 2015
18,454
Losing interest on this particular question seems to be common. This question has appeared on this and other forums a number of times and I've yet to see anyone complete the design. Most don't even try.
I never knew that the algorithm for the conversion had a name...
absf
Joined Dec 29, 2010
1,968
----Continue from post #24
Here are the files..
1. The zip file is the design file in proteus 7.80
2. The hex file for lower data ROM
3. The hex file for upper data ROM
And the original source of the hex files.
Code:
; lower data ROM
    ORG     0000
    DB    00H,01H,02H,03H,04H,05H,06H,07H,08H,09H    ;000
    DB    10H,11H,12H,13H,14H,15H,16H,17H,18H,19H    ;010
    DB    20H,21H,22H,23H,24H,25H,26H,27H,28H,29H    ;020
    DB    30H,31H,32H,33H,34H,35H,36H,37H,38H,39H    ;030
    DB    40H,41H,42H,43H,44H,45H,46H,47H,48H,49H    ;040
    DB    50H,51H,52H,53H,54H,55H,56H,57H,58H,59H    ;050
    DB    60H,61H,62H,63H,64H,65H,66H,67H,68H,69H    ;060
    DB    70H,71H,72H,73H,74H,75H,76H,77H,78H,79H    ;070
    DB    80H,81H,82H,83H,84H,85H,86H,87H,88H,89H    ;080
    DB    90H,91H,92H,93H,94H,95H,96H,97H,98H,99H    ;090
    DB    00H,01H,02H,03H,04H,05H,06H,07H,08H,09H    ;100
    DB    10H,11H,12H,13H,14H,15H,16H,17H,18H,19H    ;110
    DB    20H,21H,22H,23H,24H,25H,26H,27H,28H,29H    ;120
    DB    30H,31H,32H,33H,34H,35H,36H,37H,38H,39H    ;130
    DB    40H,41H,42H,43H,44H,45H,46H,47H,48H,49H    ;140
    DB    50H,51H,52H,53H,54H,55H,56H,57H,58H,59H    ;150
    DB    60H,61H,62H,63H,64H,65H,66H,67H,68H,69H    ;160
    DB    70H,71H,72H,73H,74H,75H,76H,77H,78H,79H    ;170
    DB    80H,81H,82H,83H,84H,85H,86H,87H,88H,89H    ;180
    DB    90H,91H,92H,93H,94H,95H,96H,97H,98H,99H    ;190
    DB    00H,01H,02H,03H,04H,05H,06H,07H,08H,09H    ;200
    DB    10H,11H,12H,13H,14H,15H,16H,17H,18H,19H    ;210
    DB    20H,21H,22H,23H,24H,25H,26H,27H,28H,29H    ;220
    DB    30H,31H,32H,33H,34H,35H,36H,37H,38H,39H    ;230
    DB    40H,41H,42H,43H,44H,45H,46H,47H,48H,49H    ;240
    DB    50H,51H,52H,53H,54H,55H                    ;250
    END
Code:
;BIN TO BCD UPPER_ROM DATA
    ORG    0000
    DB    00,00,00,00,00,00,00,00,00,00    ;LINE 1-10
    DB    01,01,01,01,01,01,01,01,01,01    ;LINE 11-20
    DB    02,02,02,02,02,02,02,02,02,02    ;LINE 21-26
    END
I am not good in C or else I'd be able to generate the source code using a short C program.
Allen
absf
Joined Dec 29, 2010
1,968
I too have some 16 data bit EPROM with quartz window. It was in 40 pin DIP by Intel from an outdated communication equipment designed by Motorola. I'll try to dig it out and take some picture of it.
Cannot remember the part numbers. But how are you going to program an EPROM with 16 bit data bus?
I have an EMP-xx programmer that was sitting inside the 8 bit ISA slot of my old PC. Not sure if it can program the intel eprom.:rolleyes:
Allen
absf
Joined Dec 29, 2010
1,968
May be it was my fault.:(
I should have used more encouraging tones in post #20 like:
"I am very sure you are able to design an 8 bit version of what I have just done....":)
instead of
"Now do you think you can do an 8 bit version of this?":D;)
Allen
dl324
Joined Mar 30, 2015
18,454
I have some hobbyist EPROM/FLASH programmers that are called Willem programmers. A number of adapters are available; one will program 16 bit wide EPROMs. They require a parallel interface and the software works best with Windows versions prior to XP. I have an old laptop running WinME for running the programmers.
Most Willem designs are open source and schematics are readily available. The software was once open sourced until the active maintainer decided to make it proprietary and made hardware changes so it would only work with his designs.
Early designs had some power deficiencies that I worked with Willem to address. He fixed the worst of them in his 4.1 version; which is what I use. He was working with someone to make a USB interface programmer, but passed away before it was finalized.
The person who made the latest hardware and software private is in your neck of the woods. His website is sivava.com. I tried to work with him to fix the power problems in his design and improve the software, but he stopped communicating with the Willem Community.
Some of the Willem programmers don't work. As I recall, that's what brought me to AAC. A post asking questions about one of the variants that was barely suitable for reading devices came up in a search and I joined to try to help him.
Brian Griffin
Joined May 17, 2013
64
instead of
Allen
I do not think the question "Now do you think you can do an 8 bit version of this?" is condescending. Many interactive tutorials and some hobby electronic magazines often ask the reader that way. :)
dl324
Joined Mar 30, 2015
18,454
The OP may come back. If he doesn't it won't be because of your post. Sometimes they have more important things to do.
People who abandon their homework threads usually do so when they find out they're expected to do most of the work.
WBahn
Joined Mar 31, 2012
33,123
I'm pretty sure that is often the case. It is also probably frequently the case that once they get enough help to complete their assignment they simply move on and don't bother to post anything further.
dl324
Joined Mar 30, 2015
18,454
No frills code to generate the table for 4 digits:
Code:
main() {
  char *cptr, tmp[5];
  int i, fd;
  unsigned int bcdn;
  fd = open("bcd.dat", O_RDWR|O_CREAT);
  for (i = 0; i < 10000; i++) {
    sprintf(tmp, "%4.4d", i);
    for (bcdn = 0, cptr = tmp; *cptr;) {
      bcdn = (bcdn << 4) + *cptr++ - '0';
    write(fd, &bcdn, 2);
  close(fd);
  exit(0);
I programmed an MC27C4002, but have only checked programming of the second word to make sure byte order was correct.
absf
Joined Dec 29, 2010
1,968
Code:
main() {
  char *cptr, tmp[5];
  int i, fd;
  unsigned int bcdn;
  close(fd);
  exit(0);
Thanks so much. I'll try it out after I come back from my holidays.
Allen
dl324
Joined Mar 30, 2015
18,454
You'll need to include some header files.
Code:
#include <stdio.h>
#include <stdlib.h>
#include <fcntl.h>
The programmer you use might expect the bytes in the opposite order. The program I use can swap bytes. If you need bytes swapped and the program you use doesn't support swapping, you can use the Unix dd command (conv=swab).
If you want to program in two byte wide EPROMs, you could modify the code example. Or write a program to separate the file into odd/even bytes, which is what I did because it might be useful for some other application.
Black Widow
Joined Jan 15, 2018
13
Thank you all for your help, I figured it out. I was all wrong about this. I made a Binary to BCD converter, and a 7seg decoder.
Again, many thanks for the tips! :)
