Hi i want to design a 8-bit asynchronous up/down counter with shift capability with minimum number of transistors.Anyone who have better design option.please let me know.
Pretty ambitious. No, I think the better design option is that you do it.
Seriously, there are numerous examples of counters and shift registers in all the logic families. Even if none of those will quite do, we have no indication from you as to very important parameters that would somewhat dictate the design. I suppose this means that this has to be an assignment, and you might not have done a lot of research just yet.
Once you have got off to a start, please do come back with specific questions.
I have to design a counter with 2 differential inputs.It should count up in +ive clock and count down during -ive clock cycle.Also it should shift the count serially.
I have designed the circuit.It counts up during +ive cycle.
1) Now i want to swap the 2 differential inputs so that it can count down.
2) I don't know how to shift this data serially.
I have to design the circuit using CMOS transistors.
Ok.Can anyone tell me how to swap 2 inputs.I have designed the up counter with differential inputs and outputs.For down counting i have to swap my inputs,but i am unable to design a swap circuit,so that for ist +ive half cycle it counts up and next + ive half cycle it counts down.
