Sanity check please.
I got some meter movements in from eBay. I have no data on them whatsoever.
They are 0-300V DC meters Inside is a series resistor which I have jumped out and a 1n007 to prevent reverse polarity. I wanted to determine the amount of current for full polarity. I placed a 10K 1% resistor in series with the meter which I actually measure at 9.98 ohms.
I measured 8.12 volts from the supply for full deflection. I measured 7.35V across my 10K.
If I am doing my math right ,that is a 735 micro amp meter movement. Or if I use my resistance measurements, 736 micro amps. Am I wrong? Seems a bit high and an odd value for a meter movement.
