7 Segment using D-Flip flop .. #2
WBahn
Joined Mar 31, 2012
33,198
Okay... so what are you expecting from the folks here? That we are going to do your work for you?
YOU need to show YOUR best attempt to work YOUR homework. WE can then HELP you by guiding you through specific trouble spots that you are having.
dl324
Joined Mar 30, 2015
18,468
Welcome to AAC! And thank you for posting the complete text for the problem because your description was incomplete.
i need urgent help of making 7 segment bcd counting 0-9 using d flip flop
When is the assignment due? You should be aware that your efforts will largely determine the rate of guidance provided.
Post the work you've done so far.
