63 mA resistor
32,847
WK4225BK-ND
The spec sheet will say 3.8 ohms
Note that the spec sheet only says that this is the nominal cold resistance. It does not give any spec at all regarding what the actual range of values are that will qualify as meeting spec.
Still, if the resistance has changed from it's previously measured value (measured under suitable and similar conditions), then something has happened to cause that change. It may or may not still be within spec, but something has caused a change, meaning that the part has almost certainly been stressed in some manner. Safe thing is to replace it with a new fuse. But, of course, that doesn't solve the problem (if there even is one), so it might happen again (with worse consequences).
Nkell12
Joined Oct 19, 2016
10
Nkell12
Joined Oct 19, 2016
10
Yes, thank you. Haha sorry for the confusion. Maybe this is something I need to contact the supplier and see what kind of range these can have. This goes in a of board which regulates voltage to extend or retract solenoids. If the solenoid does not get a certain voltage the solenoid will not actuate. So they were working with this resistor when it had 4 ohms. Now that it has 16 ohms the solenoid is not getting enough voltage to actuate.
32,847
So the spec sheet says Nominal Cold Resistance 3.8000 (Ohms)
It does?
I see that it says 3.8 Ω. Lacking any further information that implies a tolerance range of somewhere in the vicinity of 0.05 Ω to perhaps as much as 0.5 Ω.
If it says the nominal resistance is 3.8000 Ω, now we are talking about a tolerance range down in the 50 μΩ to perhaps 500 μΩ range.
Spec sheets are pretty careful (but not perfect) about only putting in significant trailing zeros that really are significant.
34,816
I don't think you are going to get much help from Littlefuse.
I say that you have the fuse in the wrong location or change the fuse to a higher current rating.
renemonte
Joined Oct 7, 2016
16
I have a 63mA resistor in one of my boards. The resistor is rated at 4 ohms and 250 v.
The problem is that I started getting a lower output voltage on a the full assembled product. I narrowed it down the the resistor and I measured it at 16.8 ohms... How can a resistor that was once 4 ohms end up having 16.8 ohms??
