60Hz to 500Hz conversion
HighVoltage!
Joined Apr 28, 2014
182
I am aware of various oscillator circuits which have the capabilities of increasing frequency.
I was wondering if a circuit could be designed with ONLY using inductors and capacitors? The frequency must be increased from 60Hz to either 500Hz or 1kHz.
Voltage output = 1kVAC at 500Hz or 1kHz
Load = capacitive and/or inductive
If this is not possible, what is the best oscillator circuit that can be used with high voltage? Is there one I can assemble on my own? Any part numbers?
Thanks for your help in advance!
MrSalts
Joined Apr 2, 2020
2,767
What voltage? Are you talking about line voltage or stepped down with a transformer? What output voltage? Since wave or square wave (other?)? What is this driving - how much power needs to be delivered to the downstream device?
Ramussons
Joined May 3, 2013
1,572
No. Since you plan to use only LC tank circuits and since neither 500 or 1000 is a multiple of 60, harmonic multipliers will not work. You will need to use active circuits like a PLL.
BobTPH
Joined Jun 5, 2013
11,678
With a square wave input possibly. A sharp bandpass filler could extract a harmonic. With a sine wave input, I don’t see how.
Edited to add: And this would be at a severe loss of amplitude.
Ian0
Joined Aug 7, 2020
13,317
What's wrong with 10kV/2A @ 60Hz?
A 20kW transformer is going to be expensive, even at 500Hz; especially at 10kV
M Feedback and Suggestions 1
