In the above image I have 4Hz. If you have exactly 4Hz you have exactly 7 changes in direction. However, if you have a continuous 4Hz (for several seconds, minutes, hours, days - etc.) then there are 8 changes in the direction of current. So in theory, in absolutely only 60Hz there are 119 changes in direction. All on the assumption you start counting at zero degrees.
Incidentally I'm editing my statement in post #10 because it's not entirely correct. What I represented was the current into an inductor.
