60 Hz AC system, change in direction of current
Status
Not open for further replies.
Alchemy One
Joined Oct 5, 2019
217
How many times the direction of current change in one second in our so-called 60 Hz AC system?
Everybody seems to say it is 60 times a second.
I think it is false. What am I missing?
Jony130
Joined Feb 17, 2009
5,598
Wee see this:
And each half of a cycle will last 1/120Hz8.4ms and the whole cycle (two half) will last 1/60Hz ≈ 16.7ms
AlbertHall
Joined Jun 4, 2014
12,640
During one full cycle, the current direction will change from 'positive' to 'negative' and back again to 'positive so the current will change direction each half cycle, thus 120Hz.
Reloadron
Joined Jan 15, 2015
7,908
My scope says that my 60 Hz house current (when there is a load) changes direction 60 times per second, my frequency counter seems to agree with that so I have to agree with the consensus.
I also read this on the Internet:
"An alternating current will flip the direction of charge flow (60 times a second in North America (60 Hz) and 50 times a second in Europe (50 Hz)). This is usually caused by a sinusoidally varying current and voltage that reverses directions, creating a periodic back and forth motion for the current".
It's pretty common knowledge that they can't put stuff on the Internet unless it is true so it must be true. I also read that on the Internet.
Maybe this would go better if you explained, in detail why you think this is false rather than have everyone else state why they feel it is true. This way people would better understand your exact, well defined, thinking on the frequency of AC current.
Ron
ElectricSpidey
Joined Dec 2, 2017
3,356
If the change at the beginning of each cycle counts, then it changes twice per cycle.
If you isolate each cycle, then it only changes once. (assuming the start at zero crossing)
Tonyr1084
Joined Sep 24, 2015
9,744
In 60 cycles, one cycle consists of a complete waveform. Starting at zero - first it goes to the (lest assume) positive peak, then it goes to the negative peak then returns to zero. That's one cycle. During that one cycle the current starts out going (again lets assume) positive, then it changes direction and goes negative, crosses the zero point, goes to the negative most part of the period, then changes direction again and returns in a positive direction to the starting point. One single cycle. During that one cycle it changed direction twice. So yes, the current changes 120 times during a 60 cycle period.
But this depends on where you start the counting. I'm starting at zero. You could start anywhere in the cycle, just be sure to count a full period. If you start at the negative point in the waveform, from there current is moving in the positive direction. Once it reaches the positive point in the waveform it changes direction (once) and heads back toward the negative point. In that instance current has changed direction only once. However, current must again change to go in the positive direction. But generally, we assume the process has been going on since before we started counting, and we always start counting at the zero crossing point.
AlbertHall
Joined Jun 4, 2014
12,640
In the diagram below, the blue arrows mark the start and end of one cycle of an AC waveform. The pink arrows mark the changes of direction. There are two changes of direction in each cycle.
Tonyr1084
Joined Sep 24, 2015
9,744
If you start at the zero crossing then you must return to the zero crossing. Starts positive, changes to negative, then changes back to positive until it reaches the zero crossing again. Remember, a cycle is a complete 360 degree movement.
{comment removed due to inaccuracy of statement}
ElectricSpidey
Joined Dec 2, 2017
3,356
Exactly, if you start the count at the peak of a cycle it must change twice to return to that peak.
No, Tony if you start at zero crossing, and count only one cycle there is only one direction change.
Tonyr1084
Joined Sep 24, 2015
9,744
@ElectricSpidey You've got me rethinking this entire thing now.
[edit] During the positive period of the waveform current is moving positive (conventional current). That's half cycle. During the negative period of the waveform current is moving negative. That constitutes a single change in direction. However, during the next positive waveform the current has changed direction again. So you're starting out with a change in direction. All positive peaks are odd numbers in the count and all negative peaks are even numbers in the count. I'm standing on 120 changes per 60 Hz.
AlbertHall
Joined Jun 4, 2014
12,640
The zero crossing point is a point of direction change. So if you go from that point to the end of the full cycle there are actually three changes of direction but you would count one of them as part of a different cycle, so we are back to two changes of direction in a cycle.
Zero to a value or a value to zero is not a change in direction or sign, it's a change in value/magnitude. If you're French, 0 is positive and negative at the same time.:D
Alchemy One
Joined Oct 5, 2019
217
Ron
You and I are both on the internet right now and we are reading it. I agree if it wasn't true they wouldn't be saying.
I believe in god, then the guy asked me which one?
I answered let me check with Ron. (just off the subject dry humor)
The only difference between you and me is this: the Internet is you and me and wait also these people. and these other people here and those........ and all of the ones everywhere. ....
https://www.quora.com/How-many-times-does-AC-current-change-its-polarity-in-one-second
Status
