ebeowulf17
- Joined Aug 12, 2014
- 3,307
Of course you are correct. Seems obvious now that you've pointed it out (but I sure wasn't seeing it before!) Thanks, it works great now.I think the problem may be that your first Schmitt trigger is biased at exactly 1/2 the supply voltage, thus the output can stay in either state with no input due to the hysteresis.
Bias it slightly low, as I did, so that with no input the output of the second gate is always low.
Also I think I figured out why I wasn't finding inverters in the voltage range / through hole combo that I wanted - I included the Schmitt trigger feature as a search parameter in my Digikey searches, but a lot of the devices aren't tagged as such. Live and learn. There are literally thousands and thousands of at least 4 different models that would meet my original plans - all I had to do was remove one search term!
