ebeowulf17
- Joined Aug 12, 2014
- 3,307
Not sure what's wrong with me, but I often shy away from 555 circuits when there are reasonable alternates. I was already thinking there should be a good Schmitt trigger solution, and before I got around to trying to design it, I found that @crutschow had already posted one here: https://www.electro-tech-online.com...sing-lm339-393-comparator-or-cd4049-gate.807/OK, now it all makes sense. This likely depends on vehicle but on one of my old trucks they used a speed pick up on the transmission. It was only a two wire sensor with no external excitation. Anyway, knowing things now I would just run your pulses into a re triggerable one shot or missing pulse detector with a slow enough RC time constant. The trick is knowing what you actually have for pulses. I do know that pulse rate will vary from vehicle to vehicle.
Sorry I was slow on the uptake.
Ron
Not claiming it's better or worse, just another option.
I'm still going to see what I can do in terms of a design without using ICs, just cause this stuff is good mental exercise for me, but I imagine the 555 or Gate based solutions will ultimately be better.
