5V charging cube: says PPS & PD 3.1 Certified
B-JoJo-S
Joined Jan 3, 2026
539
So PD 3.1 isn't just a 5V charger it can charge devices of differing voltages as well. Interesting. Thank you.
Jon Chandler
Joined Jun 12, 2008
1,644
USB-C PD chargers/ power supplies negotiate with a connected device to deliver higher voltages to increase the wattage that can be delivered. The charger will deliver only the standard 5 volts unless negotiated otherwise*.
The tables below show how a device can draw up to 240 watts instead the the customary 5 or 10 watts.
*Some devices, like microcontroller modules and consumer products wanting only 5 volts have quickly slapped on a USB-C connector without following the PD specification. They leave out two crucial resistors – when connected to a PD supply using a USB-C – USB-C cable, no voltage will be supplied. Using a USB-C – USB-A cable to a non-PD charger will allow them to work.
The Amazon listing is deficient because it does not show the voltages/currents available. For a multi-port charger, this information is critical. Many laptops require a 60 watt PD supply – 20 volts at 3 amps. A multi-port charger may claim to be a 65 watt supply, but that's a TOTAL of 65 watts across all the ports. A single port might be limited to 15 volts at 3 amps, so it won't support powering a laptop needing 60 watts.
bertus
Joined Apr 5, 2008
23,005
This is stated at the section additional details:
Input Voltage: 100-240V ~ 50/60Hz 0.65A
USB-C output: (PDO) 5V/3A, 9V/2.77A , (PPS) 5-11V/2.25A (25W max)
Bertus
Jon Chandler
Joined Jun 12, 2008
1,644
Oops, missed that detail. But it really should be front and center.
I haven't seen many supplies with the PPS feature. That could be very interesting if you can bend it to your will.
