5µs analog DelayLine @100Hz with cascaded LC-Filters
Andreas.VIE
Joined Nov 19, 2023
8
Hi everyone! I intend to delay a 1Vpp mostly sinusoidal signal in the 100Hz range for 5µs.
My first inuition was a 1000m wire, but I decided to go with cascaded LC-filters first, as in this.
\( t_{d}=\sqrt{L*C} \)=0,07µs per stage with 100nH/50nF, so I straightforwardly LTspice-simulated a couple (60-80: ) LC-filters and found the result as expected.
The prototype however shows no measureable delay @100Hz.
What am I missing here?!
  • can I expect an actual delay, or will a bunch of LC-Filters only generate an equivalent phaseshift?
  • the phaseshift of my filter above should be zero, as 100Hz << fg=2.25MHz?
  • I totaly ignored impedance issues. i.e., the input is a generator@50Ohm, the output is high-impedance, the whole network is low-impedance. Is this a problem?
for context: This network's output goes to a voltage-to-current converter. As Input-Driver I thought of an LTC6373 PGIA.
What are your thoughts of my contraption here? Any help is greatly appreciated!..
AnalogKid
Joined Aug 1, 2013
12,287
First of all, phase shift *is* delay. If a 100 Hz sine wave zero crossing is delayed for 2.5 ms, with no other waveform distortions, that is a phase shift of 90 degrees.
Second, 60 stages of 0.07 us per stage is only 4.2 us of delay. If you are looking at a 100 Hz signal on a scope, that is below visual resolution.
I would use an opamp circuit called an all-pass filter.
https://wiki.analog.com/university/courses/electronics/text/chapter-4
http://www.ecircuitcenter.com/Circuits/op_allpass1/op_allpass1.htm
https://www.allaboutcircuits.com/technical-articles/focusing-on-phase-the-all-pass-filter/
ak
Andreas.VIE
Joined Nov 19, 2023
8
thank you AnalogKid for the swift response! As I understand it, phaseshift and delay can be equivalent, but to be pricise, I need a frequency-independent true delay.
This is a tricky topic, as many articles (e.g.) explain the similarities and differences, and I obviously havent fully grasped it. In essence I question if I can expect a frequency-invariant td=sqrt(LC) from my circuit?
  • I can immagine a transmission line of defined length (e.g.) causes the req'd delay as propagation delay.
    I can also believe the equivalent model of lumped LCs serves the same in all aspects.
  • I also stumbled across the opamp-allpass-circuit you pointed out above.
    Seen as filter, the phaseshift is obvious, I just don't see where a delay should arise.
  • I also found that my pile of LCs could be arranged in an allpass- instead of lowpass-configuration.
    But would that change anything in my case f<<fg ?
It's true, to measure the desired effect is tricky. It's 0,05% of the signals periode. Luckily I've got a decent DSO.
But I also doubt this at this point - am I measuring crap and should see a true delay @100Hz?
On the xact number of stages req'd; In my application it's necessary to calibrate the delay in small increments, so having 80 stages gives me enough room to maneuver - theoretically.
Alec_t
Joined Sep 17, 2013
15,160
With a fast microcontroller perhaps you could A/D convert the input signal then spit it out ~5uS later to a D/A converter?
Andreas.VIE
Joined Nov 19, 2023
8
I am soo tempted to do xactly that ADC/µC/DAC thing.
But I refrain from it until I can rule out this cheap analog solution.
Andreas.VIE
Joined Nov 19, 2023
8
Let me add some more background to this story. We're measuing Power. And the Voltage-path experiences a (digital) delay in the order of 5µs. Thus I delay the current-path likewise, in order to get a precise powermeter-reading.
The actual Powermeter is a Yokogawa WT333E, the Voltage Amplifier/Divider is a Rohrer Arcus T303B.
The "bandwidth" is only 50Hz ... 200Hz.
yet the precision of the powermeter reading must meet reference standards sub 0,5%.
Ian0
Joined Aug 7, 2020
13,306
So you are introducing a phase shift of 1.57m rad.
The error in the power will be 1-cosφ, and cos(1.57 mrad) is 0.9999987. The error in the sampled signal will be unmeasurable unless you have a 20bit A/D, and to achieve that you need a SNR of 117dB in the rest of the measurement circuit.
Andreas.VIE
Joined Nov 19, 2023
8
An important detail to omit. Over what frequency range? AND - what delay tolerance across that bandwidth?
And, again, in the context of this thread, phase shift is delay. It may not be frequency-independent, but it is delay none the less.
50Hz ... 200Hz << fg=2MHz
the tolerance of the voltage-path-delay is small, it's digital, so consider it constant, 5µs i.e.
if I translate this from delay to the phase-world, we're looking for a phase-linear allpass-filter, right?!
Andreas.VIE
Joined Nov 19, 2023
8
thank you much for pointing this out so fast. the maths of the expected error doesnt match the perceived error by (at least) two orders . This was and still is my initial splinter of doubt to the bigger picture.
however; in this thread I want to focus on the task of a 5µs delay line in the 100Hz range.
38,909
As Ian0 noted, compensating for that small delay results in a basically unmeasurable error, so you are spending time and effort for no improvement in your results.
That's poor engineering.
Andreas.VIE
Joined Nov 19, 2023
8
There are quite a few companies and engineers working on this issue right now, and some of them act poorer than others ;) regardless; a phase-error in power-measurment is a systematic error that can be corrected., which is my task here.
38,909
Then you are working for a poorly run company.
But the either a low-pass or all-pass filter will do what you want, since the phase-shift/delay you want is so small.
AnalogKid
Joined Aug 1, 2013
12,287
The period of a 50 Hz waveform is 20 ms. 0.5% of that is 100 us. That is 20 times greater than the 5 us delay you are trying to achieve. I know that this does not translate directly into the processed reading accuracy, but it looks like you are chasing false precision.
Another way to look at it: at 50 Hz, 5 us is 0.09 degrees of phase error. For this to matter, every single downstream component / subsystem in the instrument must be at least 10x better than this for this to have a direct effect on the last digit of a reading.
Or something like that.
ak
Ian0
Joined Aug 7, 2020
13,306
If you must pursue this sisyphean task then who am I to stop you, but how are you going to prove that you have achieved it?
