Protoboard Project 555 Wide Range Oscillator
Wendy
Joined Mar 24, 2008
23,803
Sorry I've had this thought rattling around in that empty space between my ears. I haven't built it yet but I have all the parts to:
when I finish this will be a completed project and I will start a new thread, for now I am opening the subject for ideas and iterations. There will be a 3D printed box to go with it, and if I can get it to work it a frequency counter.
Ian0
Joined Aug 7, 2020
13,220
One of your MOSFETs is upside down. I don’t know which one, as I don’t know if you intended it is an inverting output, or a complementary source-follower.
(a low-side MOSFET gate driver would make a nice output buffer)
DickCappels
Joined Aug 21, 2008
10,662
At times I have put a small resistor in series with each drain to limit the short circuit current during switching. That can probably be also done by the selection of the MOSFETs so their RdON is high enough.
Tonyr1084
Joined Sep 24, 2015
9,744
Did something quite similar. Only instead of a rotary switch I used dip switches. It's possible to select one of four caps or a combination of each, all the way up to all of them. Off hand I don't have the schematic handy. It's somewhere. Also featured on this board is the IC socket where you can put much larger caps into the circuit. With all the dip switches open only the applied capacitor will affect the circuit. If the desired frequency is a little too high it's possible to switch into the circuit some of the other caps and slow down the clock rate. If I locate the schematic quickly I'll post it.
Wendy
Joined Mar 24, 2008
23,803
I have the same kind of breadboard stock, and I have updated my schematic mistake. I will probably use a protoboard for this next design, since soldering is such a pain for me.
DickCappels
Joined Aug 21, 2008
10,662
You have me stumped. Why all those diodes on the adjustable output?
Edit: Is there a chance of hurting Q3 by having it try to drive all those diodes with more than 2.5 volts?
Wendy
Joined Mar 24, 2008
23,803
Perhaps I should have drawn this schematic differently, if you look very close the diodes are not connected to the output variable output. The diode chain only crosses the variable output without actually making contact, the combined drop of all those diodes should be around 3.6 volts. Which is what a TTL output should be. Vcc is defined on the protoboard drawing, which is 12 volts. I plan on playing with the actual voltage on Vcc, I may use an external power supply instead of batteries.
Ian0
Joined Aug 7, 2020
13,220
Just a thought on the logic level output:
The CD4050 will run off a 5V supply and take an input of up to 18V, and each section will drive two TTL loads.
Wendy
Joined Mar 24, 2008
23,803
I may use 8 AA batteries, haven't decided yet. When I start designing the 3D printed box, that's when I will make the final decision.
Wendy
Joined Mar 24, 2008
23,803
So I have 3D printed a case for this project, and now I am working on the protoboard again. I tried this one:
the mosfets were a total bust, they loaded down the CMOS 555 to the point where it was not usable. Interestingly, I tried a 7555 and a TS555CN, the TS555CN blew the 7555 out of the water. Now I will addition BJT's to see if they work better. I will let you know.
Audioguru again
Joined Oct 21, 2019
6,826
Mosfets have a very high gate to source capacitance that is a heavy load at high frequencies.
Usually a pair of transistors (complementary emitter-followers) is used to drive high frequency Mosfets.
Wendy
Joined Mar 24, 2008
23,803
If I am going to use BJT transistors I will use only BJT transistors. Latest brain part:
I will live with the shoot through.
Audioguru again
Joined Oct 21, 2019
6,826
The Cmos 555 has a rail-to-rail output only when the load current is almost zero. The common-emitter transistors you used need a HUGE base current (10 times the collector current) to saturate. The huge current at the output of the Cmos 555 reduces its output voltage swing.
Emitter-followers do not have a huge base current because they do not saturate, instead they amplify with the low base current determined by the high hFE beta.
