555 Timer example
WBahn
Joined Mar 31, 2012
32,840
So to be on the road then:
F=1/TH+TL
then TH=1/F+TL
TH = 1/50 Hz + 9.52*10^-3
TH = 0.029 sec ==> 29.5 mS
right ?
You are being extremely sloppy with your math and your equations and it is biting you big time.
The total period is 1/f and is also the sum of the high-time and the low-time. So
1/f = TH + TL
So
TH = (1/f) - TL
King7
Joined May 14, 2016
31
1/f = TH + TL
So
TH = (1/f) - TL
yes i know what you mean i totally forgot to put subtract instead of the sum
thanks
i'm being dizzy like that all this time
cause week ago my gf broke up with me and i have to solve this for tomorrow homework and like i said i'm kind of new at this
WBahn
Joined Mar 31, 2012
32,840
All the more reason to slow down, take it step by step, and verify that each step really does follow from the prior step. Also a very strong reason to properly track your units. Most of the mistakes we make screw up the units and let us determine that (1) we messed up, and (2) where we messed up, almost immediately. But that is only true if the units are there to get screwed up in the first place. Throwing numbers at equations and then tacking on the units that you want the final answer to have is a sure way to get lots of wrong answers that you fail to catch.
King7
Joined May 14, 2016
31
you are right bro
thanks
King7
Joined May 14, 2016
31
hey guys how are you
today the teacher played a game on us and made the homework exam and some other things including my 555 timer homework
so this is what i wrote to solve the equation
the values the teacher want us to determine are (R1) and (duty cycle)
the values are the same in the photo i gave you but this time the frequency is 42 Hz
TL = 0.7 C1 R2
TL = 0.7*(680*10^-9)*20000
TL = 9.52*10^-3 sec ==>9.52 mS
F = 1/T
so T = 1/f
T = 1/42
T = 0.02 sec ==> 20 mS
T(total) = TH + TL
then TH = T(total) - TL
TH = 20 - 9.52
TH = 10.48 mS
am i right until now guys cause my friend said it's wrong
bertus
Joined Apr 5, 2008
22,925
Wich photo says 42Hz?
The calculation for T=1/42 will NOT give you 20 mS.
You where saying 50 Hz yourself.
The TH is indeed 10.48 mS.
Now you can calculate the R needed for this time.
The R2 you want can be found using the total resistor value found and subtract the 20 K of R1.
Bertus
King7
Joined May 14, 2016
31
Bertus
yes i know
the photo say 50 Hz
but in exam today 42 Hz
bertus
Joined Apr 5, 2008
22,925
I have take an other calculator that says 1/42 = 0,0238095238095, so you will have to use that for the further calcutaions.
Bertus
bertus
Joined Apr 5, 2008
22,925
Recalculate TH as it is not 10.48 mS anymore.
When you got the new TH value, you can calculate the R needed for this time.
Bertus
King7
Joined May 14, 2016
31
Bertus
but what's the point i got it wrong in today's exam so no use :'(
bertus
Joined Apr 5, 2008
22,925
By doing it now, you can get used to doing calculations like these.
You will only learn by doing it.
When we give you the complete answer, you will not have gotten the grasp on how to do the calculations.
Bertus
King7
Joined May 14, 2016
31
Bertus
yes i know bro you are right
but tell me something
are my steps true don't care about numbers
just the steps
