Keep track of the prefix factors:
http://educypedia.karadimov.info/electronics/metrixprefix.htm
Bertus
Bertus
i know them broHello,
Bertus
if you mean the (R2) which is (20k=20000)That also is not correct.
1) Where are your units?
2) Given a frequency of 50 Hz, what is the period? That is all the information your need to calculate it.
Just look at the units. What are the units of frequency? What are the units of period?
John
cause i wanted to make mathematical shortcut some howHello,
Why do you not use them in your calculations?
Bertus
yes ,, sorry i know itHello,
When R = 20K it is 20*10^3 or 20000 and not 2000.
Bertus
TL = 0.7 C R2Hello,
So using the formula on the image:
What is TL?
Bertus
Be more specificAs for my question in Post #20, if frequency (Hz) is in "cycles/second" and period is in "seconds/cycle", then given a frequency of 50 Hz, what is the period?
John
Yes and not the 9520 mS you gave in post #19.TL = 0.7 C R2
TL = 0.7*(680*10^-9)*20000
TL = 9.52*10^-3
So to be on the road then:Hello,
Bertus
Total! That is the "period," which I defined in #31.Be more specific
TL or TH or T total ??
T=1/fHello,
When f=1/T , the what is T if f = 50 Hz?
Bertus
T=1/fTotal! That is the "period," which I defined in #31.
Good luck.
John
